Cluster gear sign
ali10006
alo
Dubai
Ford Ranger Raptor
Today I have notice that when am driving the car on D and then I used the paddle shifter to shift down or up there will no sign on the cluster of the gear, and if i hold it + peddle it will show D driver.
Previous if I used the peddle on the RPM cluster it will show the gear number.
Any solution for that?
ali10006
alo
Dubai
Ford Ranger Raptor
What am saying is that when am driving the car on D drive and I used the paddle shifter the D sign will disappear from the cluster ( without gear number ).
Previous it was showing the gear number on the cluster
ali10006
alo
Dubai
Ford Ranger Raptor
This is what i mean
Ford Ranger Cluster gear sign IMG_4779
Ford Ranger Cluster gear sign IMG_4778
SubaruRaptor
Jory
North
Quantum Gear Ratio obviously.
PlebbythePlebapus
Ed
Michigan, United States
2022 Ford F150
Prototype Vehicle Coordinator
This is an actualy issue for you. I would take it into the dealer. In Normal mode, the gears should show if you are pressing the paddle shifters or in Manual mode.
949BFN
Hendré
South Africa
2023 Ranger Raptor
Attorney
Did you make any changes with Forscan? I saw a similar issue after playing around with the instrument settings with Forscan.
ali10006
alo
Dubai
Ford Ranger Raptor
yes i did on Forscan some changes, but none of them related to the cluster. That why I was confused.
so by forscan can i solve it?
ali10006
alo
Dubai
Ford Ranger Raptor
He's from Dubai so I have to presume he's not fluent in "Murica''.
thank you for your reply. And yes am from Dubai, and am fluent in English. But maybe the issue that I had was hard to explain it so I tried to explain it as much as I can.
ali10006
alo
Dubai
Ford Ranger Raptor
Just an update for this issue, I have just found the solution in the form.
previously I have add on TPMS - Display tire temperature in addition to tire pressure and the code was wrong ( as the value was to 9 ) and the correct value should be ( A ).
So I have changed it again and it work fine.
