Configuring the R button?
docshelby
Macan Turbo
Optometrist
I’ve watched several videos, they say it can be programmed to you specific modes, but don’t show how to do it. I think there might be something wrong with my truck. I saw something about the R button not working. I cannot figure out how to customize the settings to the modes I want? What am I doing wrong? Help, thanks!
pappacrunch
Kevin
San Diego
1955 Ford F100
I had to go out to the truck to remember how to do this. Pick the item you want on the steering wheel and then hold down the R button until the little bar moves all way across showing the save status. If you let up before it goes all the way across then it will not save.
As an example: Select the exhaust setting you want (i.e. quiet) and then hold down the R button. Watch the little bar go across while it is saving, after it is saved let up the R button and presto magico your new exhaust setting is now set when you use the R button. Do the same for the other items. There is not a bulk save (that I am aware of).
After you get everything set you press the R button twice to get it into R mode.
John B
Kansas City, Missouri
2024 ford ranger raptor
retired engineer
You can actually set up the RR as you want it, exhaust, steering, suspension, auto stop off, middle screen, and then save it all at once using the R button function. Works great
docshelby
Macan Turbo
Optometrist
I programmed everything but the auto stop start, and the differential. How do you do that? Thank you.
0ak9
GA
you press all the corresponding buttons to set up your RR to your liking and then hold the R button to save it. once you start the truck up, press the R button and all of your saved preferences come back up.
Cyrusblack
Banned
Banned
Pasco County
Perhaps I missed something here - is the R button only available with the RR? Or is it something that is available to the Lariat’s and XLT? If yes then where is said button located?
“Man who ask Question dumb for 2 minutes. Man who doesn’t ask Question dumb for Life”
0ak9
GA
The R button is for the RR.
Cyrusblack
Banned
Banned
Pasco County
