Custom Fog Light Mount
CT801
Utah
Got them back form powdercoating, I have 4 more available!
Thunder175
Tom
Northern Virginia
2026 Ford Ranger Lariat
Science and Engineering Technical Advisor
@CT801 Do you have any of these brackets still available? And what lights did you use for the bolt pattern? Those look like Diode Dynamics.
Was also curious about potential negative side effects since that area is marked as air flow intake for the intercooler. Anyone seeing negative side effects?
CT801
Utah
I designed them to have some room to adopt a number of lights, obviously with each light you may have to add a spacer for desired height. The lights in using are Code 4 LED’s, but yea similar to DD.
I’ve had those lights mounted basically since I got my truck in January of 25…been through a very hot summer and a cold ass winter. Hasn’t affected anything. I do still have 2 available!
Thunder175
Tom
Northern Virginia
Awesome! I just saw another thread about guys talking about possibly blocking airflow to the intercooler with lights in that area. But since I'm not pushing the truck hard and am usually in eco mode I doubt it'll make a big difference.
Just one more question. I assume these will bolt up to the same position on non-RR Lariat's with the ACC radar? I know there are grille and general front end differences between the Lariat and RR but the underlying mounting points I would assume are the same? If anyone can confirm fitment on Lariat and below trims I would appreciate, and CT801 will have one more sale!
CT801
Utah
Yea I drive in Sport mode pretty much all the time and have seen nothing detrimental.
I can’t confirm on the mount spot for a lariat, but I’d bet it’s the same. But the guys here should be able to nail it down!
Thunder175
Tom
Northern Virginia
Since no one has replied yet, do you have any pics or instructions from when you were fitting and installing the bracket? I can crawl under there to compare with the Lariat. If It bolting to the radar mount location I can't imagine it would be different on the Raptor but better to be safe than sorry. I'd really like to do this option so I can get some real amber fogs and leave the OEM fogs alone since there isn't a real replacement solution for the Lariat that's truly plug and play.
mhorvath1218
North Jersey
‘24 Ranger Raptor
Finally got mine mounted up today with Diode Dynamics SSC2 pro’s. Looks awesome! Just gotta get them dialed in at night
Ford Ranger Custom Fog Light Mount IMG_4506
Ford Ranger Custom Fog Light Mount IMG_4504
Ford Ranger Custom Fog Light Mount IMG_4505
CT801
Utah
Hell yes!!!! Well done! They came out awesome!
mhorvath1218
North Jersey
‘24 Ranger Raptor
Thanks man, really appreciate the effort making these. Its exactly what I was looking for. Dealing with all those metal clips was kind of a bitch though!
CT801
Utah
Right!? They are absolute bastards! I’m glad you got it installed, those lights look awesome!
CT801
Utah
Looks awesome, any issues with airflow?
Nope! I’ve had mine in for well over a year, made it through a winter and a really, really hot summer here in Utah. Not one problem at all!
