Engine reving up to 4000 rpm while braking
RangerQC57
Jacques
Quebec City, Canada
Ford Ranger XLT 2025 FX4
I have a 2025 Ford Ranger XLT with a 2.7L V6 engine, and when I approach an intersection and brake, I feel the engine strain, and I need to press harder on the brake pedal to control it. If I put it in neutral or park, the engine revs up to 4000 RPM, and as soon as I release the brake pedal, the RPMs return to normal. As long as my foot is on the brake, the engine runs at 4000 RPM. I went to the dealership where I bought my Ranger, they checked it, and there are no fault codes. The mechanic told me that because the battery was at 60% charge, it could be the cause. But I charged the battery to 96%, and the problem has occurred repeatedly. Also, I don't touch the accelerator pedal when my foot is on the brake. Has anyone else experienced this problem, and if so, what was the solution?
waffleso_0
Oakland California
24 Ranger XLT 2.7L V6
Did you let them drive it to re-produce the problem?
thats so weird. i would normally say there is a vacuum leak in the booster or its associated plumbing but you have an electronic booster, right?
jmt8706
2025 Ranger Lariat
Are you in manual mode when it happens? Same thing happened in my ram, although not as high as a rev when I shifted down for slowing, or engine braking. It was more of a gear range select instead of a manual shift.
RangerQC57
RangerQC57
Jacques
Quebec City, Canada
No, I'm always on automatic. I just checked with AI and they suggest it may be a faulty sensor in the brake pedal when the auto start stop is on. I will try it tomorrow.
RangerQC57
RangerQC57
Jacques
Quebec City, Canada
I imagine it's an electronic one, my Ranger is a 2025.
waffleso_0
Oakland California
They only plug it on their computer and said that there is no error codes. I'l go to another dealership to have it checked.
Yeah, I would have had them drive it with you so you can see if it happens to them as well. They won't be able to say it's nothing if it replicates itself.
mAtTyG04
Matthew Glazier
Edmonton
2025 Raptor Ranger
AI:
1. The Most Likely Culprit: Brake Booster Vacuum Leak
The fact that the engine revs specifically when you press the brake pedal and returns to normal when you release it is a classic symptom of a massive internal vacuum leak in the brake booster.
  • How it works: Your engine uses vacuum pressure to help you press the brakes. Inside the brake booster, there is a rubber diaphragm.
  • The Problem: If that diaphragm is torn, pressing the brake pedal opens a hole that sucks huge amounts of "unmetered" air directly into the engine intake.
  • The Result: The engine computer sees this sudden rush of air and dumps in fuel to keep up, causing the RPMs to skyrocket to 4000. You have to press the brake harder because you’ve lost the "power assist" from the booster, and you're fighting the engine's attempt to accelerate.
2. Why "No Codes" and the "Battery" Excuse?
  • No Codes: A mechanical leak in the brake booster diaphragm doesn't always trigger a code immediately because the computer thinks the "extra air" is just a massive change in throttle position or a temporary surge.
  • The Battery: Modern Fords are very sensitive to battery voltage (State of Charge), and low voltage can cause erratic sensor readings. However, charging the battery to 96% and still having the issue proves the mechanic's theory was wrong. A low battery will not cause a 4000 RPM surge only when the brake is applied.
3. Immediate Steps & How to Talk to the Dealer
This is a Safety Issue (Unintended Acceleration). Do not let them give you the truck back until it is fixed.
  • Demand a "Brake Booster Vacuum Test": Ask the lead technician to perform a vacuum hold test on the booster. They should also check the check valve and the vacuum line running from the engine to the booster.
  • Mention "Unintended Acceleration": Use those exact words. Dealerships take that phrasing very seriously for liability reasons. Tell them: "The vehicle is accelerating against my braking force, creating a safety hazard."
  • Video Evidence: Since the problem is repeatable, record a video of the dashboard showing the RPM gauge hitting 4000 while your foot is clearly on the brake and the truck is in Park/Neutral.
danmoochie
dan
florida
retired Sales manager
find a new mechanic, he's a moron, there is something wrong with the truck, no battery would ever accelerate your engine while braking.
AI:
if he has a vacuum brake booster. we think he doesn't since its a 2025
mAtTyG04
Matthew Glazier
Edmonton
2025 Raptor Ranger
Think you're right! I called AI out now it's giving this:
Since your truck uses an Electronic Brake Booster (eBB) rather than a vacuum booster, the traditional "vacuum leak" diagnosis (which usually causes a rough idle, not a 4000 RPM surge) doesn't apply here.
The battery explanation from the dealer is almost certainly a brush-off; while low voltage causes weird sensor glitches, a consistent 4000 RPM surge tied specifically to the brake pedal points to a software logic conflict or a faulty pedal assembly.
Here is what is likely happening:
1. Brake Pedal Position (BPP) Sensor "Cross-Talk"
The 2.7L EcoBoost uses a "Drive-by-Wire" system where the accelerator and brake pedals are essentially just sensors sending electrical signals to the ECU.
  • The Theory: If the Brake Pedal Position sensor has an internal short or a "noisy" signal, it could be bleeding voltage over to the Accelerator Pedal Position (APP) circuit.
  • The Symptom: The truck thinks you are asking for 4000 RPM worth of throttle because it's misinterpreting the electrical signal from the brake pedal.
2. The "Brake Over Accelerate" (BOA) Logic Failure
Modern Fords have a safety feature called Brake Over Accelerate. If you press both pedals at once, the ECU is programmed to ignore the gas and prioritize the brake to prevent unintended acceleration.
  • The Theory: In your case, the logic seems to be inverted or corrupted. When you hit the brake, the ECU is mistakenly triggering a throttle increase.
  • Why it stops when you release the brake: Releasing the pedal resets the state of that specific sensor circuit, causing the ECU to return to "Idle" logic.
3. Electronic Brake Booster (eBB) Feedback Loop
Since your booster is an electric motor, it pulls a significant amount of current when you press the pedal.
  • The Theory: There may be an electrical ground issue or a short in the eBB wiring harness. When the booster motor draws power to help you brake, it is creating electrical interference with the engine's throttle body motor or the pedal sensors.
What to do next (Since the Dealer found "No Codes")
"No codes" does not mean "no problem." This is a classic case where they need to perform Data Logging while the truck is acting up.
  1. Demand a "Flight Recorder": Ask the dealer to hook up their diagnostic tool (IDS) and record the "Live Data" for APP (Accelerator Pedal Position) and BPP (Brake Pedal Position) while you replicate the 4000 RPM surge.
  2. Look for "Ghost" Throttle: If the logs show the APP sensor jumping to 25% or 30% while your foot is only on the brake, you have objective proof of a faulty pedal assembly or wiring harness.
Ironwood
Atlanta
2025 Ford Ranger Raptor
Retired electrical contractor
When my RR is in sport mode, it downshifts aggressively as I stop. I haven't looked at my tach, but the rpms certainly jump. Is there any chance that is what you feel?
