Faulty washer fluid sensor?
dram32
SoCal
2024 Ford Ranger XLT
Facilities Technician
My trucks windshield washer fluid low indicator went off about two months into having the truck. Checked the wash fluid reservoir and it was a little low so I topped it off. After topping it off I used the washer fluid maybe twice and lo washer fluid indicator came up again. I checked my reservoir today and it’s barely below full. Has anyone had similar issues?
Ford Ranger Faulty washer fluid sensor? IMG_0465
Hootbro
Delaware
2024 Ranger STX 4X4
What type of fluid did you top off with? Fluids with Rain-X or similar additives have been known to mess up fluid washer sensors.
CodeOrangeUAE
LUKE
Abu dhabi
Ranger raptor 2024
I get same... and just top it up once a month.
Just using regular water.. thought i just might be using the washers a lot :-D
dram32
dram32
SoCal
Not 100% sure I had some laying around the garage so I used it to top off. I’ll have to check once I get back home. Thanks for the info!
dram32
dram32
SoCal
That’s what I thought but I only used it maybe 4 times when I first got the truck before the indicator popped up. Then topped it off used it twice within a couple weeks of topping it off and boom it’s back on. Not that big of an issue just annoying seeing that indicator every time I’m driving.
Ford Motor Company
Official Ford Account
Ford
Dearborn, MI
Ford Ranger
Hi David! I can look into your Ranger's concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Ranger's VIN?
dram32
dram32
SoCal
Message sent
