HighDesertRanger
Oklahoma
Ford Fusion 2.7
Sales Manager
Thank you! I swear I thought I saw a reply asking about fitment- I left rake in the system when the Dobs coils were installed, so it rubs at full lock right now. But Im 99% sure if I just adjust the coil preload it will be fine- stay tuned on that one.
Yeah, that was me too. I misread and thought you’d put the 35s off the Bronco in there. Then I realized those were 33s. Reading is fundamental 🤦‍♂️
Fix4Dirt
Fix4Dirt
SLO County, CA
No worries! We all do that 😆
Fix4Dirt
Fix4Dirt
SLO County, CA
Thank you man! Its a super sweet rig couldnt be happier
ggsm111
Grady
virgina
Lighting: Used Auxbeam switch panel, ran my GMRS antenna coax thru the port too.
Used 2" Alluminum plate to mount the fuse panel and breaker. Only mod to the auxbeam stuff was to crimp and solder a 90 on the positive side, since it wouldnt fir the cap.
Love your auxbeam install. For the plate you have holding the auxbeam fuse box, how did you mount it to the truck? I see a factory threaded hole im guessing you used to hold the right side so was hoping you knew the thread size. what did you do on the other side?
Fix4Dirt
Fix4Dirt
SLO County, CA
Hey man thanks for the quesrion! I dont have the rig with me at the moemnt but Ill be sure to get back to you when Im back with it again.
Fix4Dirt
Fix4Dirt
SLO County, CA
As I recall I ran the bar stock far enough back that it reached another hole if memory serves me right
ggsm111
Grady
virgina
Where did you hook the ground wire for the auxbeam to?
Fix4Dirt
Fix4Dirt
SLO County, CA
Hey dude sorry to take so long to get back to you I hope this helps. I took pictures of where the plate is mounted to.
Ford Ranger Fix4Dirt 2024 Ranger Build IMG_4740
Ford Ranger Fix4Dirt 2024 Ranger Build IMG_4741
Ford Ranger Fix4Dirt 2024 Ranger Build IMG_4742
Fix4Dirt
Fix4Dirt
SLO County, CA
Sorry also for a late response. I have a pocture attached where it comes out of the fuse panel and its wrapped around and geounded to the bracket as shown. Hope this help!
Ford Ranger Fix4Dirt 2024 Ranger Build IMG_4744
Ford Ranger Fix4Dirt 2024 Ranger Build IMG_4743
Fix4Dirt
Fix4Dirt
SLO County, CA
Heres a picture of the panel and the ground cable comes down and around.
Ford Ranger Fix4Dirt 2024 Ranger Build IMG_4745
