Forscan and 2025
bigb
Tucson
2025 Ranger 2.7
Who is using Forscan on a 2025 Ranger for live data? I am curious if it is able to see transmission temp and oil temp? I am also curious if it is compatible with Android Auto? I need a newer version of Forscan (I'm running an ancient version on an ancient tablet and it just keeps crashing) but ran out of time today.
I tried Torque Pro and it had very little info, next I borrowed SG III out of my Sprinter and it has transmission temp but no oil temp but I do need to update my SG III which I'll do tomorrow. I need to see if there are any files available for torque pro as well for the newer Fords.
edit: I just found out there is no EOT sensor on Rangers so no EOT data stream.
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
You can view trans temp on the same screen your turbo psi and engine oil pressure is on the offroad menu-engine info(or similar name) on the dash. engine oil temp is on the dash as an extra guage. But I am running OBD Link(only compatible with the obd link mx/mx+ bluetooth reader) and the app is AA compatible.
Only displays 4 pids at a time when in drive, park will dispaly them all, but you can set up extra screens for it. Im running Trip fuel liters used, coolant temp in celsius, fuel remaining in liters, and boost psi when I run the extended display. I think the mx+ enhanced diagnostics update for obd link lets you see the trans temp. I just use the one on the dash to keep track the trans temp.
dash display left is coolant temp, rpm, speed/lane keep assist, boost, oil psi, trans temp, oil temp, fuel.
Ford Ranger Forscan and 2025 20251201_191453
Ford Ranger Forscan and 2025 20250809_160350
