Exterior lighting too. It's actually surprisingly handy when not wanting to disturb others when camping.
That is very handy. Something ai wish I knew about before my last trip. Does the setting affect approach lighting?
jezzza
Jezza
Brisbane, AU
2022 Ranger Raptor
‎‎ Engineer
Yeah it disables approach lighting (if enabled) too.
craigc
craigc
Craig
Allen, TX
Turns out it does enable a Sync Menu option too. Really confused why Ford disables these features by default. I can see leaving them off, but why remove the button. I added this to the confirmed tab with the instructions. Works great!
jezzza
Jezza
Brisbane, AU
2022 Ranger Raptor
‎‎ Engineer
Too bad that's not a sync option. I like having the exterior lighting most of the time, but wish could have easy way to turn on/off silent mode using the panel or a switch rather than Forscan. Helpful while camping as has been stated...
Sorry I missed that, I should have said it does. Big fan of any new added menu items too!
Ford AU released the 'Platinum' Ranger here 2 years into the cycle with some of these menu options enabled from factory, I guess it's a marketing/packaging strategy.
shraptor
Australia
ranger raptor
Has anyone tried to turn the little number values for the displayed small gauges. Underneath the fuel gauge it shows DTE. I’d like to also see oil pressure, coolant temperature etc.?
i have seen it turned on but I don’t know what forscan function it is.
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet IMG_8353
RangerDangerStranger
SF Bay Area
2024 XLT 4x4 in GreyBlue.
Cool Dude
Added Mud/Rut, Sand and Rock Crawl Mode, Changed my auto blinker to 6 blinks, Set my headlight switch to remember the last setting, and set my Fogs to on with high Beams. So cool.
RR404
Germany
Ford Ranger Raptor 2.0
Has anyone an idea how to add the eco mode from the maverick or bronco to an Europe Ranger Raptor 2.0 Diesel from 2024? I would appreciate any help.
I tried the plain text menu but it didn’t work.
MoreRai
I have been able to get most things to display the numerical value except for the oil temperature and oil pressure values, for some reason they are the only ones that I can't get a number below.
I enabled the axle temperature graph as well and it's now available as one of the middle two graphs. All of the changes were in the IPC module and I just searched for "temperature" and changed the values.
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet dashboard
Adding temps is cool. I added the tire temps to the pressure screen. Definitely helpful when running lower pressures. I'll have to look for the rest while adding silent/dark mode.
shraptor
Australia
ranger raptor
Thanks for the heads up. I tried doing that and had a mix of good and bad results Fuel has changed to, 0 and 1 instead of E and F, I managed to get transmission temperature to work though.
Do you know what you specifically changed?
shraptor
Australia
ranger raptor
Ok I figured it out. I needed to force the gauges to alphanumeric then all the gauges showed up correctly. Still would love to get engine pressure.
craigc
craigc
Craig
Allen, TX
I'll try to get that added to the sheet. This is good stuff!
craigc
craigc
Craig
Allen, TX
I am unable to see the "measurements" on the center cluster. is that a new option in Main menu that showed up for you, or did it exist already? I enabled "menu-temperature gauge detailed settings", but still don't have it. I only could get engine temp and tranny temp on the top gauges.
Wondering if the settings you did are specific to Raptor only.
