HyperM3
Lawrenceville, NJ
Has anyone been able to figure out how to enable gear indicator in RPM guage when in any mode other than Sport?
MoreRai
I am unable to see the "measurements" on the center cluster. is that a new option in Main menu that showed up for you, or did it exist already? I enabled "menu-temperature gauge detailed settings", but still don't have it. I only could get engine temp and tranny temp on the top gauges.
Wondering if the settings you did are specific to Raptor only.
the measurements screen is a factory setting that I believe is Raptor only. I was able to enable some addtional measurements inside that, but the menu itself was already there.
craigc
craigc
Craig
Allen, TX
anyone try these and/or know what they do? I hoped continuous gear display kept the gears always displayed under the PRNDM, but it does not.
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1726534170631-ud
shraptor
Australia
ranger raptor
I haven’t but I would very much like to have the selected gear on display over just showing D (drive). Keep us posted if you test any further
Raptor1996
Anton
Ohio
Hello everyone. I am trying to see if there is a way to adjust the temperature setpoint for the heated steering wheel. I have scoured the asbuilt data and can't find any information on this, but I have another thread where a couple people told me I could with forscan and one person even said they found it but won't tell me where it is. Can anyone point me in the correct direction? Im extremely familiar with forscan, I don't know why I'm having so much trouble with finding this parameter....
craigc
craigc
Craig
Allen, TX
I (thought) I just posted on that other thread late last night that I found it. but when you posted this realized it was still sitting there waitng for me to submit. Doh!
it's in the SCCM module
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1726840132899-54
If you get a chance to try this and confirm it works, please post back here or PM me and I'll add it to the "confirmed" tab of the spreadsheet.
I never found it, and discovered today that in my experimentation a week or so ago I somehow turned off the tach gear indicator in anything but Manual mode. The flappy paddle trick in drive no longer works, and center tach display in Sport/Drive is completely blank. Oops
Anyone know what I may have changed? I have a feeling it may be something with the transmission mode being switched from manual to auto somewhere, but figured I'd ask here before I start playing around again.
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 20240920_144824
HyperM3
Lawrenceville, NJ
Have you been saving your modules before you make changes? I generally name the module after I make whatever change it was. Even if I have 12 modules at least I know which one I made the last change on and can revert to the previous one if I have to.
I think so, but honestly not sure if those saves are being done correctly because, well, I'm a typical guy who never RTFM. ?
I turned on adaptive front lighting system. Not sure if it actually turns on the matrix style lighting ROW has, but it gave me a new setting in the center stack for right or left lane driving, so if you know what it is supposed to do versus what we got in NA, might want to try it out. I don't know enough about the differences to know what to look for.
a77cj7
Sturgis, SD
98 Ranger
I have been able to get most things to display the numerical value except for the oil temperature and oil pressure values, for some reason they are the only ones that I can't get a number below.
I enabled the axle temperature graph as well and it's now available as one of the middle two graphs. All of the changes were in the IPC module and I just searched for "temperature" and changed the values.
Any luck with the oil pressure?
Oil temp does have a value display on mine, by changing the oil temp gauge to “enabled”
shraptor
Australia
ranger raptor
I managed to do this a year or so ago and iI think it happened when I added the tyre temperature. The value below should be "A" not "9" for raptor, 9 seems to work for other variants.
TPMS - Display tire temperature in addition to tire pressureIPC720-11-01xxxx-*xxx-xxxxChange value of * to 9
MoreRai
no luck with oil pressure or oil temperature. I will go in again and make sure I have the gauge enabled.
