JWeigel
North Dakota
Along this line.....I would love to NOT have 4A come on with Tow Haul. Have not tried putting the truck into Tow Haul mode then seeing if one can change the drive type to 2W from 4W.
jjw
ND
Stumpm2
Wyoming
Ranger Raptor, F350 Tremor
Not sure on 4A in Baja, but I can change mine to 2H in Baja. I can also change mine to 2H in Tow/Haul.
cleffe
Cgrus
24 Ford Ranger Raptor
Baja exhaust or baja mode? If I try to switch from 4H in Baja mode, it tells me I can't.
Stumpm2
Wyoming
Baja mode. I have done it several times in my Ranger Raptor and previously in my Bronco Raptor.
CarTuner
Australia
Next Gen Supercab Ranger XLT BiTurbo
Mine's an NZ Raptor. Should be similar. Here's what I've got working so far.
Power Delivery (To Wheels) Gauge in Cluster
Turbo Boost Gauge in Cluster
Tow/Haul Mode
Trail Turn Assist
Auto Lock Doors on Motion
Lane Keep Assist Removal
Lane Change Blink Number
Enable Reverse Camera and Hitch View at Speed
Engine Temperature Gauge - Show Temp Value Below Gauge
Transmission Temperature Gauge - Show Temp Value Below Gauge
Fuel Gauge - E to F
Turn Off Seat Belt Reminders
TPMS Default Units - PSI
TPMS - Display tire temperature in addition to tire pressure
Frost Telltale (Below 5 deg) - Not sure if working, since it's summer.
Thanks brother! Appreciate it!!
Will have to see if some of these work on the XLT...
Waffel
Orlando, FL
Does anyone know if it’s possible to code the daytime running LEDs not to dim when the low beams are on?
I’m pretty sure this is in non asbuilt, but also I remember someone was saying they kept getting flashed because it was too bright for oncoming drivers so maybe not a great idea.
Waffel
Orlando, FL
Sequoia
Dan
Germany
Ranger Wildtrak 2023
Great. Thanks.
I will try it next week, after my trip to Miami
sloon
Michal
Česká republika
Ford Ranger Raptor 3.0 V6, 2023
Has anyone tried turning on the front wheel view like the Bronco has?
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 325
Sequoia
Dan
Germany
I had it exactly like that a few pages earlier. The symbol is there, but it doesn’t seem possible to activate it. Too bad. Maybe someone will figure it out after all.
