Fuse box diagram / table?
Garaged
Usa
Ranger raptor 2024
Has anyone found the right fuse box diagrams that match the under-hood fuse box (and for that matter the interior one as well) for the 2024 Ranger (Raptor if it matters)? The attached picture is what mine looks like.
However, I can't correlate the fuses - them being populated even in many cases - to the numbers in the table on sites like fuseinfo. https://fusesinfo.com/ford/fuse-box-diagrams-ford-ranger-2024 Am I just reading them wrong? For instance, I'm looking at the lower right of my photo - fuses 44, 137, 9, 2 - but there are only 3 fuses in that row and I can't seem to match them up against the descriptions either for one of them.
For context, trying to find 'safe' fuses to tie in the amber grille lights (super low consumption ~7 watts) + the amber DRLs of A-pillar lights and maybe a grill light bar's Amber DRL (like the M&R one).
Pardon the dust, I got hit by a storm of pollen while working on the grille amber light install.
Ford Ranger Fuse box diagram / table? 20241029_214649
Catalyst
Justin
Bend, OR USA
Network Engineer
Catalyst
Justin
Bend, OR USA
Network Engineer
With a Raptor, why are you not using the pre wired AUX upfitter options? Those are documented by location and colors of wiring leads in the manual
Garaged
Usa
Ranger raptor 2024
I do use aux1 for my grille lights for now but I'd rather reserve them for lights that need control rather than ones that are low power and that I'd like on all the time.
Garaged
Usa
Ranger raptor 2024
Not sure if these help or not but these are ford diagrams I pulled from a raptor
This matches so much better (though I guess F141 is the only one missing in the list)! Thanks a ton. You wouldn't happen to have the interior ones too, would you?
Now I just need to decide which fuse is something less critical that I can tap with an additional 5A fuse without worrying.
Jon52
Jon
Illinois
This matches so much better! Thanks a ton. You wouldn't happen to have the interior ones too, would you?
I think these should be the interiors.
Garaged
Usa
Ranger raptor 2024
Thank you! Are these all in the manual already and I've not looked hard enough? What is the source?
Garaged
Usa
Ranger raptor 2024
Jon52
Jon
Illinois
I work at a dealer so I just looked it up on my own truck
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
Does anyone know why the diagram and the index on this document doesn't match up? For Example there are multiple #70's fuses shown but none listed in index. For example I'm looking at the truck and there is one fuse populated in a #70's position and it's either shown but not listed or not shown/not listed I forget. Plus a single position matching as a (some amp rating I forget now)micro 2 SPARE is actually live/hot with key off? If anyone with more knowledge than I could assist that would be awesome! Thanks
