Probably never, if cali has a say in it
Goosetuned
Goosetuned
Gold Sponsor
Winfield
AZ, NM, TX
Professional Tuner
Shouldn't be much longer!
Goosetuned
Goosetuned
Gold Sponsor
Winfield
AZ, NM, TX
Professional Tuner
Got the COBB wheels installed! Totally different look!
These wheels are 22lbs each!
Ford Ranger Goosetuned Tuning R&D - Ranger/Bronco 3.0 Raptor +300hp! Ranger Raptor (3)
Ford Ranger Goosetuned Tuning R&D - Ranger/Bronco 3.0 Raptor +300hp! Ranger Raptor (4)
Ford Ranger Goosetuned Tuning R&D - Ranger/Bronco 3.0 Raptor +300hp! Ranger Raptor (5)
Ford Ranger Goosetuned Tuning R&D - Ranger/Bronco 3.0 Raptor +300hp! Ranger Raptor (7)
boeingDriver
Orlando
Stage 2 + BOV activated!
I think I'm going to combine stage 1 + Stage 2 (e40) in the same vlog
S and B intake and Cobb the way to go for intercooler and intake? Was trying to do research on all the options and figured I’d just go right to the best tuner and source to ask!
did you maintain the active factory grill shutters for the intercooler?
Goosetuned
Goosetuned
Gold Sponsor
Winfield
AZ, NM, TX
Professional Tuner
Thank you!
S&B has been my favorite/easiest to get. The COBB intercooler is great. Process west stage 2 is bigger, but more expensive and harder to get.
The COBB intercooler does retain the AGS
Thank you!
Doesn't the COBB eliminate the rear passive shutters though? If my understanding is correct, they are intended for low speed off-road use, crawling / trail work, since the radiator can pull some air in through the IC to keep temps in a certain range as gravity will pull them down so you can draw a vacuum in front of the IC via the radiator fan.
As far as I know, the German company Wagner is the only one I know of to keep both, but maybe I'm wrong on that.
RaptorME
Maine
I believe you are right about the Wagner after watching install videos. It is also FAR cheaper than the Cobb. That is the route I will end up going, no need right now since we are in the middle of the coldest winter in a long time here in Maine!
Goosetuned
Goosetuned
Gold Sponsor
Winfield
AZ, NM, TX
Professional Tuner
Yes the COBB deletes the rear. Which has been ok from my testing. Wagner is also a little bit smaller than cobb
Caneman88
Ron
2025 Ranger Raptor MB GLC 300
Pella
How does the Cobb AP compare against the FP Pro Cal ?
Pro Cal says it adds 50hp to the engine and Cobb does HP to the rear wheels the correct way IMO
I currently have the Pro Cal tune on my RR but like anything We want more power trying to talk myself in to the Cobb AP if it makes the difference.
Goosetuned
Goosetuned
Gold Sponsor
Winfield
AZ, NM, TX
Professional Tuner
I just did a video on the FPC vs My custom tune, I didn't dyno the COBB tune.
The nice thing about COBB is you can work with a pro tuner and the sky is the limit
Goosetuned
Goosetuned
Gold Sponsor
Winfield
AZ, NM, TX
Professional Tuner
Here is the latest Ranger Raptor vlog!!
boeingDriver
Orlando
this is why Goosetuned is the ONLY name in the game now especially because he personally owns the Ranger Raptor. Excellent work!!!!
any spark plug changes recommended with your stage 2 intercooler and intake?
I’ll be ordering from you soon in the spring!!!
Goosetuned
Goosetuned
Gold Sponsor
Winfield
AZ, NM, TX
Professional Tuner
Thank you!!! Much appreciated man!
the NGK Ruthenium plugs I sell are what I recommend.
Can't wait man!!!
and he is very popular in the f150 raptor world too. he did my buddy aaron's hennessey raptor last year
