Headlight wiring harness plug wire identification
rangerblack95
overseas
2024 Ford Ranger XLT FX4
I'm trying to find out which wire in the headlight harness plug is the one for drl. I have an LED grille I want to hook up to the harness and solder to but I don't know which one it is. Would it be the same as the Australian and British rangers?
edjee
WA
2024 Ford Ranger Lariat FX4 2.7
Did you ever get the info your looking for? I'm in the same boat, I got some grill lights from ebay and trying to figure out which wires to tap into.
rangerblack95
overseas
I basically prayed and hoped for the best that the wires were the same as the international ranger. Turns out it was. If you look up on YouTube ford ranger nighthawk grill installation, the video will tell you which ones to tap into for the DRLs. I did the process exactly how it says and it worked perfectly.
Neil S
Neil
2025 Ranger Lariat FX4, 2005 Ford Explorer Sport-Trac XLT 4x4
EHS Manager
RoughRider
Carol
Utah
2025 Ranger Raptor, 2020 Ranger has new home
Just hooked my grill lights (US version) up to the DRL, works great. Based on that video was able to find the DRL wire at the back of the driver's headlight plug - thin gray wire with blue trace. Although the wire harness did not have enough give to be able to tap into it from the top of the engine compartment, wound up accessing it through the drivers fender well. Just a few screws and plastic pin clips to separate the 2 pieces of felt wheel well liner enough to pull the plug harness out far enough to tap into the wire.
Neil S
Neil
EHS Manager
Thanks for your insight. What model year is your Ranger?
Neil S
Neil
EHS Manager
Thanks, mine too! You didn't pin-out any of the other wires by chance? I need the turn signal wires too.
Sauce
Northeast
2025 Ranger XLT FX4
I recommend turning off the drl wink w Forscan if you are tapping that wire. Otherwise the grill lights will turn off when you use the turn signal on that side. Maybe its just my OCD, but I found that weird.
Neil S
Neil
EHS Manager
Thanks. Your insight to getting more slack is helpful.
BTW, did you get the brake booster recall? I'm having mine done next week.
There is also a side curtain airbag shield installation recall. This recall the parts are not available yet.
RoughRider
Carol
Utah
It works fine, stays on even with the turn signal
Sauce
Northeast
2025 Ranger XLT FX4
Thats odd. The DRLs turn off with the turn signal unless they are changed in Forscan. Maybe you tapped something else?
Mattsraptor 2025
Europe
2024 Raptor
I’m looking to install F150leds LED Grille kit into my EU Raptor
and go through the DRL wire in the headlamp harness.
Do you have any issue with the LED’s when you switch on the dipped headlamps and the DRL’s dim down?
I read somewhere that with the DRL’s dimming, any lighting accessory that’s tapped into the DRL wire will be affected?
Neil S
Neil
EHS Manager
I was able to get this interim wire harness from SPV with 2 pigtails, 1 for the DRL, 1 for the turn signal. Probably cost me $45 more than the normal one but, I don't have to worry about cutting/splicing into my harness. This way I can plug in this short harness with the 2 pigtails and plug in my XkGlow I also asked for the male Weather tight connector to crimp on the Switchback wires. Switchbacks for my front grill. (picture shows their off-the-shelf harness) I'll let you all know when I get it installed!
Ford Ranger Headlight wiring harness plug wire identification 1758835390933-bm
Ford Ranger Headlight wiring harness plug wire identification 1758835669816-0r
