Help With Amber Lighting for 2024 XLT
GrantHughes27
North Carolina
2024 Ford Ranger XLT
Am I stupid? Trying to install Amazon amber lights on 2024 Ranger through fuse box. Won’t turn on. Please help, feel like I’m missing something obvious.
Ford Ranger Help With Amber Lighting for 2024 XLT Screenshot 2025-10-16 at 2.49.11 PM
Ford Ranger Help With Amber Lighting for 2024 XLT Screenshot 2025-10-16 at 2.49.54 PM
Ford Ranger Help With Amber Lighting for 2024 XLT Screenshot 2025-10-16 at 2.49.41 PM
Ford Ranger Help With Amber Lighting for 2024 XLT Screenshot 2025-10-16 at 2.50.04 PM
BigOleOgre
Nate
STL MO
Field Service Engineer
also note that alot of fuses are powered when "engine on" only.
There are so many diagrams for the different trims on the ranger, the raptor has some of the same fuses and some different than the xl/xlt/lariat , however i did find a thread that had a schematic that lined up with my fuse box exactly, unfortunately i doubt i can find it again. Do not go by any "fuse box layout stickers from amazon" they are incorrect. Try to find the direct ford fuse diagram for your trim.
If though that's how the instructions show, IMO that's not a secure grounding method.
BigOleOgre
Nate
STL MO
Just noticed that as well, I made my negative connection to the - battery and positive connection here, my lights are on when engine on for reference.
Ford Ranger Help With Amber Lighting for 2024 XLT 20251016_143959
GrantHughes27
North Carolina
Would you mind sending me a picture of where you grounded it on the battery?
ericsmr
FordGuy
West Coast
2025 Ford Ranger XLT FX4
Hello! I went through this pain not too long ago and went direct to fuse box myself. 25 XLT
Only worked with engine on, what I ended up doing is wiring it to the side marker on the driver side so now it turns on with the unlock button as well as at night when my lights are on.
Since the side markers aren’t DRL, they don’t stay on mid day while driving but this is something you can change with forscan. The only other option is to wire into actual headlamps/DRL if what you’re looking for is DRL for the ambers
otherwise the side markers setup I have works great and are on when the lights are on or with unlock button for a quick picture
if you’d like I can try and find the video showing the wiring process for the side markers
ericsmr
FordGuy
West Coast
Hello! I went through this pain not too long ago and wend direct to fuse box myself.
Here is the video
Please note I didn’t use t connectors as they are fragile, I cut the wire clean and rewired pos and neg using heat shrink butt connectors
