Horrible noise on cold start up of Ranger Raptor?
JimmyRR
Jimmy
NSW
Ranger Raptor 2024
Has anyone come across their new gen Ranger Raptor making a terrible noise on first start up of the day?
It almost sounds like my old diesel without enough oil in it.
It is going into ford next week for a diagnosis, but it would be good to know if this has happened elsewhere and what the outcome was.
Thank you
coldconfession13
Albert
Usa
Chevy Colorado ZR2
IT
turbo. My edge makes the same kinda noise.
Bonus Oz
Bruce
Cairns Australia
23 Raptor , 72 Escort RS , 89 Sierra Cosworth , 60 Mini Cooper, 72 Mini Hayabusa
Wheeler Dealer
There is a few units in Australia that have had a problem with valve springs which that sounds to me.
Dealers are fully aware and have been sent the memo via ford.
Make sure they send the oil away for analysis when they have rectified the valves as they have authorized dealers to change the engine if further damage has been caused by a result of the bad valve springs.
Crapblaster
If the valve springs were bad, it seems it would continue to be noisy. It sounds more like cam phasers that are leaky and as pressure comes up they quit rattling.
1TruckLife
Indiana, USA
2019 Ford Edge ST, 2024 Ranger Raptor
Mechanical Engineer
Sounds like the cam phasers. Sounds similar to the issues that the 3.5EB had from the 2018-19 Model years.
olefordguy
Craig
Alabama
Yep, they had to be replaced on wife expeditions 3.5L under warranty. Ford made dealer try 2 different software updates first before they ultimately had to replace phasers. Didn’t make the noise on warm startup
Xyotafella
Derek
‘23 Tacoma Off Road
Machinist
Don’t look like the easiest of jobs to do either on some models!
Crapblaster
He also could have a one of a kind diesel starter motor.
JimmyRR
JimmyRR
Jimmy
NSW
Ranger Raptor 2024
The noise only happens for less than 2 seconds.
that's really interesting thank you. Same scenario, the noise does not occur after the engine is the slightest bit warm. only cold start up.
olefordguy
Craig
Alabama
Correct, pretty involved process. I think the recall/tsb paperwork ford sent us showed like a 3 day job. Well it turned into 6 weeks total due to parts availability. Thankfully got a great dealer, they gave us and brand new f150 with 4 miles on it as a loaner the entire time.
coldconfession13
Albert
Usa
Chevy Colorado ZR2
IT
correct it goes away once engine warms up.
ivotuk
Ray
North Pole, Alaska
2019 Ranger Lariat
IT
Sounds like lifters to me. They are supposed to pump up, and hold that pressure from the day the engine is new. But as they wear out, random lifters will *knock* until oil pressure brings them up tight against the push-rods/valves. The fact that it goes away so quickly is more evidence for lifters.
A few specks of dirt during assembly could cause it, or just defective lifter seals.
My buddy used to take a stethoscope and put it on the valve covers to identify the source of the noise. I always just put my fingertips on the valve cover, and you could feel the clatter.
Good article on lifter noise:
https://soundproofwiz.com/quiet-noisy-lifter/
Ford Ranger Horrible noise on cold start up of Ranger Raptor? Lifter Components
olefordguy
Craig
Alabama
I ran across this while searching ford cam phaser. May or may not apply with your model year but sounds like same issue. Check with your dealer
https://www.tsbsearch.com/Ford/23-2183
