How does your tailgate open? Is this common?
kirkster89
Kirk
Saskatchewan
2025 Ranger, 2.3, fx4, Lariat
If I close the tailgate normally (no excessive force) the tailgate doesn't sit flush against the body/taillight on the passenger side, the handle is easy to open, the sound of it unlatching seems normal as well.
If I firmly close it or slam it shut the tailgate sits fairly flush to the body but when you go to open it the handle doesn't engage until it is basically lifted all the way up to the max and given a decent squeeze. When it finally does unlatch it makes a nice loud pop. It feels almost like I'm opening an old worn out tailgate from 2005...
Ford Ranger How does your tailgate open? Is this common? PXL_20251003_190604715~2
Ford Ranger How does your tailgate open? Is this common? PXL_20251003_190555364~2
AugPal
Augie
Chicago
Retired IBEW
Something is not properly adjusted. Mine closes like your second picture. And is smooth without slamming. Ford should be able to fix that easily unless something is tweaked.
Ditto. Mine closes with no slamming. Dealer should fix that
kirkster89
kirkster89
Kirk
Saskatchewan
I figured so... I'll get them to look at it at our first service. Trucks about a month old less than 3000km (1800miles). My list is growing lol...
Thanks!!
kirkster89
kirkster89
Kirk
Saskatchewan
Thanks! I figured it couldn't be proper 🤣 I can see it now.. 2 years from now i'd have to be giving people instructions on how to get it to open "you have to push it in then pull" 🤣🤣
stuartmunto
Stuart
Perth, Western Australia
2023 Ford Ranger Raptor
Do you have a roller shutter? I find if the roller shutter is closed you need to slam the tail gate to get it to fully latch. If the shutter is open it latches with ease and very little effort.
kirkster89
kirkster89
Kirk
Saskatchewan
Just a soft tri fold tonneau cover, but same results with it open or closed
my son's does that too. he noticed it the first time he closed my tailgate. he told me about his and i told him to take it to the dealership, or we could adjust it ourselves, though i would do dealership since the truck is not even a year old. i guess he took it to them because we never messed with it.
he lives in omaha so i don't get to see him regularly to remember to ask about this
alrashid2
PA
Mine doing the EXACT same thing as yours! Did you ever figure this out?
kirkster89
kirkster89
Kirk
Saskatchewan
According to the dealership it was bent.
I noticed this pretty soon after getting the truck so maybe it was like that from the factory. If it was me who bent it these tailgates must be very fragile.The heaviest thing would probably be a 210lb person sitting on it 🤣
Apparently they bent it back, the gap on the passenger side is still sort of there but the latch is smooth now
alrashid2
PA
Thanks for reporting back.
I got tinkering in the last 15 min and fixed mine too mostly.
What I could see is, from inside the bed, that when you slow close it, the latch was not fully latching. Only partially! Like you, if I slammed it, it'd go flush and the latch would fully latch, but then you'd get that terrible pop. I also noticed metal wear on the stud the latch grabs.
I loosened the metal stud with a large torx bit and found that is adjustable! I played around with it a bit and moved it forward a bit - you can see in my photo where the circular paint mark is where it originally sat.
The tailgate is slightly not flush still on passenger side, but now it doesn't clunk when opening, latches fully, and is consistent when opening and closing.
Ford Ranger How does your tailgate open? Is this common? PXL_20260806_160529711
alrashid2
PA
Hey when you say bent, do you mean the entire tailgate assembly was?
kirkster89
kirkster89
Kirk
Saskatchewan
Sorry, I honestly have no idea. I know the mechanic and he asked me how the tailgate was after I got the truck back, I said it was good and asked what they did and all he said was "they straightened it. 🔨" So I just assumed it was bent lol. Now that I think of it maybe they straightened the latch pin...
alrashid2
PA
Ha geez! I've noticed that after my tinkering, the tailgate is better but not totally right. Still feels a bit clunky when opening. Not sure if that is normal or not...
I'll probably keep an eye on it and if another issue comes up, hit 2 birds with 1 stone and go in for warranty work.
alrashid2
PA
Just got out there tinkering more. I noticed it was still sometimes clunky, though not as bad as before, and I also noticed that the latch was not fully latching over the "stud" (Don't know exact terminology).
I moved the "latch stud" a hair more forward and a bit downward too. Now there is zero clunkiness whether I slam it and open it or slowly shut it and open it. The latch is now fully latching over the stud instead of partially!
Only con is now I can see that the tailgate is not sitting evenly... it's not fully flush on the driver's side, never was, but it's definitely not flush on the passenger side. My tonneau is pretty much centered and if you follow it, I can see now that the tonneau covers about 1/8" to 1/4" less on the passenger side top of the tailgate due to it sticking out more.
Rather it not be flush and latch and open/close correctly. Just wanted to share for any future readers!
