ChasVSRaptor
ChasVSRaptor
Charles
Seats look awesome.
Curious if it might be possible to get the cooled option with Katzkin and kerp the OEM heated seat integrated within the trucks systems.
IE. I can control my heated seats from my Ford app. I can remote start truck, set the climate system , turn on my heated steering wheel, heated seats all from the app.
I am thinking I would like to keep the heated seat function controlled by the truck and simply add the cooled function on that seat mounted switch.
Curious if that’s an offered optional way of doing it?
That would be easy to find out. Just ask Katzkins! Https://katzkin.com/contact
some_guy
some
florida
entrepreneur
did you do the backseats too? have any pictures of those?
BRZ, Mustang Bullitt, Outback
Yeah, not quite Sherlock.
The Katzkin Degreez (also styled DegreeZ) is an aftermarket OEM-style heated/cooled seat system (typically Gentherm-based thermoelectric technology). It uses a TED (thermoelectric device / Peltier module) that creates a temperature differential: one side cools while the opposite side heats (or vice versa when polarity is reversed for heating mode).
How the airflow works
  • A blower draws cabin air and passes it across the TED.
  • Conditioned air (cooled or heated) is directed through ducting and distribution pads into the perforated leather/reticulated foam of the seat cushion and back, exiting through the perforations toward the occupant.
  • The opposite (waste) air stream—hot when the system is cooling the seat—is exhausted through a separate port/duct.
Installation practice (and similar Gentherm/TED systems) routes this waste exhaust under the seat or out the bottom of the seat back/cushion foam, often with a bezel or vent tube. This is done so the hot waste air does not recirculate inside a closed seat back and reduce performance.
Effect on the rear compartment
Exhaust under the front seats releases that warm air into the cabin space beneath and behind the front seats. In most vehicles this area connects to (or flows toward) the rear footwells and rear seat compartment, so some heat does enter the rear area. The volume is modest compared with the vehicle’s main HVAC system, which can generally dissipate it without major impact, but it is not zero.
In heating mode the waste side is the cooler stream, so the exhaust is cooler rather than warmer. Exact routing and any noticeable effect depend on the specific vehicle, seat design, and how the installer orients the exhaust duct. Professional installers typically aim to keep the exhaust away from direct occupant contact.
You called me Sherlock and then posted something that 100% agrees with what I said.
The difference is I was speaking as an actual back seat passenger that felt the heat dump in the back seat and not some marketing guy selling seat covers.
The vehicle I was in was a new 2017 Chevy full size with OEM seat cooling. Seat cooling was pretty new to me then and I didn’t know the truck had seat cooling. At first, I just thought the AC sucked for Houston heat. But it kept getting hotter in the back seats instead of gradually cooler as we drove to the work site.
It was a company truck in Houston during the summer. The heat dump from the seat basically felt like an impressively good heater to me in the rear seat.
This won’t matter if nobody was in the back, but I can tell you the front seat passengers were completely unaware of how hot it was.
Since you own a completely different and much newer truck and seat, you could probably drive the truck around for a bit on a hot day with the cooling on then ride in the back and provide some useful firsthand info.
Or just leave the rude comment and cut and paste marketing statement stand.
Caneman88
Ron
2025 Ranger Raptor MB GLC 300
Pella
I did mine a few months back and the has double heat the factory option and the added Degresz
The cooled option works better than my 2021 F150 Platinum did not even close
Chente04
Congrats! Actually thought someone resurrected my old thread because we almost got the same pattern lol. Southern heat and humidity dont play!
ChasVSRaptor
ChasVSRaptor
Charles
Yeah, saw they got combined. Since I have a Ranger Raptor I went with their stock Raptor look seats with Red accents and just added the insert as you did.
went with both heat and cooling even though I seldom need the heated seats here in Florida, but was looking ahead for resale impact if I ever let this thing go.
DirtDerrick
Nathan
Atlanta
dirtderrick.com
People Person
Yes.
Back to the seats. I’m jealous of the cooling, like someone said earlier, only option I miss.
Reminds me of 2007, first new Escalade, messing with the buttons while flipping through the 340 month payment book, I blushed a little as I figured out it had cooled seats, (mesh shorts commando, overshare).
Enjoy them! I might get some too when I get the antique Escalade paid off.
O
Love it when people who don’t know shit make such comments. The unit does actually cool the air up to 15 degrees lower than drawn in air temperature. So it’s not just ventilation as you claim.
RonEee
Ron
Holland Michigan
2025 Ranger XLT
Very cool and all but my Ranger came with heated seats and air conditioning standard. Not sure I understand the value of air conditioned seats unless it's just the wow factor??
ChasVSRaptor
ChasVSRaptor
Charles
Yeah, definitely not a wow factor issue. That’s what lifts and light bars are for 🤣!
OxygenMask
Phil
Eugene, Oregon
O
Lighten up dude! Don't tell you've never had one tequila too many while posting on forums..... :fistbump:
Sportshot2
Jerry
2019 F 150 FX4 (totaled) 2021 Acura RDX, 2021 KIA
Katskins being installed as I write this. I chose the pumice color to complement the truck and be unique. Ford still thinks they are in the 1900's when Henry Ford said you can have any color you want as long as it's black. I will find out tomorrow if I wasted $3800 to get cooled seats.
My logic is I'm 78 years old and I enjoy this truck so much it will probably be the last truck I ever buy. If I waited for Ford to do it the sales tax alone would probably run close to $3800. Heated and cooled seats and the Ford Procal tune should keep me satisfied. Yup it was a lot of money but I can't take it with me
