Level/Lift and Tires on the way
scubajosh77
Alabama
So I got my shop to order the Superlift 2.5" leveling kit for the front and the 1.5" blocks for the rear. Went with the Cooper Discoverer AT3 XLT in 275/70R18. $2300 for everything installed. Hopefully everything will be here in the next couple weeks.
These tires are 22lbs heavier than the OEM Goodyears. I'm certain I'll take a hit on mpg. Anyone think I should be concerned about other wear and tear due to the additional weight?
Will post up pics when done. Need to read up on using Forscan to correct the spedo/tire diameter.
scubajosh77
Alabama
Before and after pics. Was dark when I picked her up so had to take em at the gas station and in the garage. Happy with it but am now thinking I want another inch in the rear. Measuring from the top center of the tire to the bottom center of the wheel well the front is about .25” higher.
Ford Ranger Level/Lift and Tires on the way IMG_2799
Ford Ranger Level/Lift and Tires on the way IMG_2818
Ford Ranger Level/Lift and Tires on the way IMG_2812
Ford Ranger Level/Lift and Tires on the way IMG_2813
scubajosh77
Alabama
Well I found out this morning why the rear was still low. The shop didn't install the rear blocks! Waiting on them to open to have that conversation. Kinda pissed.
scubajosh77
Alabama
Yeah. So they said they 'forgot' to tell me they didn't install them because they didn't have U-Bolts. Supposedly U-Bolts will be in today or tomorrow and they'll install it. Still pissed.
AUME1996
Ranger
Any rubbing? How close is the inside of the front tire to the knuckle?
Ford Ranger Level/Lift and Tires on the way 1740081209905-r
scubajosh77
Alabama
I'll try to get a good pic. It's close, but no rubbing.
jeffers
Jeffrey
Nevada
2024 Ranger FX4, Mk7 GTI
No rubbing, are you running spacers or anything? Are those rims a +55 offest? Also how close are you to the crash bars?
Alaska Steve
Alaska
No idea what wheel offset is. No spacers. Best pic I could get.
Stock wheels on the Lariat are:
7.5Jx18 ET55 offset: 53 - 57 (55)
Bolt Pattern (PCD): 6x139.7 (6x5.5)
Thread Size: M12 x 1.5
garyo
Winnipeg
Ranger
Your truck looks great. Do you happen to have any pictures of the poke along the sides front to rear shot? I have the Ranger Lifts 2” (not installed yet) but not sure yet what I want to do with tires and wheels. I have some aftermarket 17’s but I don’t mind the stock Lariat wheels now that my truck arrived. But want a little beefier look. Weighing my options. Thanks!
scubajosh77
Alabama
Best I could do
Ford Ranger Level/Lift and Tires on the way IMG_3092
garyo
Winnipeg
Ranger
Fantastic, I appreciate you taking the time. Looks very good and exactly what I’m looking for. Cheers!
Oldbarn70
NH
2024 F150
Finally finished and extremely happy with the stance. Also getting just over 20 mpg and I was getting 21 before. Not as bad of a hit as I’d expected.
Thing looks mint.
