MAV
MAV
Arkansas
Can you elaborate on this a bit more? Thx.
The control arm bushings don't rotate around the bolt. Once the bolt is tightened, they don't move. But because they are rubber, they stretch in rotation when the control arm moves up and down. So within the bushings' limited ability to stretch (which is always more than the suspension can move - otherwise, they would tear immediately), the control arm can move up and down and rotate the bushings around their center.
When installed from the factory, the bolt is tightened when the suspension is at normal ride height, meaning that the bushings are not stretched when the truck is sitting still at ride height. They only stretch when the suspension flexes up or down. You'll see this when you remove your knuckle from the upper ball joint. The upper control arm will spring up into its normal ride height position due to the elasticity of the bushings.
Now, when you insert a 2" spacer at the top of the shock, you've effectively moved the static ride height of the whole suspension 2" down. The control arm bushings are now in a constant state of being stretched in rotation around the mounting bolt. The only time it ever gets back to "normal" is when you hit a bump that compresses the suspension 2". The remedy for this is to loosen the upper control arm bolt so the bushings can rotate, and pull down on the control arm until it rotates a couple of inches lower. Then tighten the bolt.
The ONLY thing this does is possibly add some life to your upper control arm bushings. It's not a big deal, otherwise it would have been included in the instructions. It's just an easy procedure to do while you're in there, so I did it. The same logic applies to the lower control arm bushings, except when you loosen those bolts, you're screwing with the camber/caster alignment. If you're going to take it in to have an alignment done anyway, go right ahead.
ag02m5
Google
Thank you sir! Debating if I want to tackly myself. Either way good to have an understanding to make sure the shop does it the best way possible.
MulchBags2
I believe I like the silver beauty rings from the bronco than the ranger grey beauty rings. Am I the only one?
MAV
MAV
Arkansas
They're growing on me. They don't match the fender flares very well, but as a friend pointed out, they match the stainless exhaust and the front lower fascia and belly pan. I'll probably leave them alone.
Ford Ranger Leveled Ranger Raptor on Bronco Sasquatch Wheels/Tires 1730077014001-bs
chrisriner
Holly Springs, GA
Mobile App Developer
So essentially putting 35's on it? Do you know how much more ground clearance you have now?
stovall977
Stu
oil and gas/real estate
This is exactly what I plan to do, but I’m going with Foutz or SVC 2” or 2.5 spring collar lift. 2” looks perfect to me, you still have a slight rake which looks best. Great work. Did you take any measurements before and after in the front.
