Matte black Airplex Hood protector installed on Desert Sand 2025 Ranger.
DesertSand
Alberta
Null
It's finally warming up in Alberta Canada. Washed the truck and installed the Airplex Hood protector I ordered off eBay before Christmas. Very easy to install. The only thing I noticed on the final steps was the plastic clip that is on the corners is so tight it tears the protective film you put on the corners of the hood when pushing the clip on. Other than that. Perfect fit and look!!
Ford Ranger Matte black Airplex Hood protector installed on Desert Sand 2025 Ranger. IMG_20260404_181224234_HDR
Ford Ranger Matte black Airplex Hood protector installed on Desert Sand 2025 Ranger. IMG_20260404_181420287_HDR
bigb
Tucson
2025 Ranger 2.7
Looks good! On mine I didn't use the thin pieces of film they gave me, instead I cut some slightly bigger ones out of some 3M PPF I had on hand. I also warmed up the clips with a heat gun so they'd soften a bit and go on easier.
I'm happy with mine, in fact with all the black on the front of mine it makes the truck look taller. I want to eventually paint that gray lower part black as well, I think that will really make the front look like it means business!
Ford Ranger Matte black Airplex Hood protector installed on Desert Sand 2025 Ranger. 20251118_134256
DesertSand
DesertSand
Alberta
Null
Yours is looking great too!. Definitely good advice and pointers. I was afraid of making the clips too loose by warming them. Mine are definitely not going anywhere 😁
I saw one in a F15O when I was at the dealer getting my oil changed today.
‘I thought it looked pretty cool on there. Was wondering if they made them for Ranger too.
Very cool.
droidXer
Billy
Upstate NY
25 Ranger Raptor
How was it pushing the friction inserts through the rubber gasket and deflector?
DesertSand
DesertSand
Alberta
Null
How was it pushing the friction inserta through the rubber gasket and deflector?
The pushpins that come with it went in great and then you screw in the metal screws supplied to expand it.
Trimjb
Tennessee
2024 Ranger FX4
How are they for keeping bugs and debris from hitting the windshield?
My windshield take a beating on cross country trips.
DesertSand
DesertSand
Alberta
Null
We will find out soon enough. The bugs will be coming out soon here.
TommyWasabi
Thomas
North Alabama
2026 Ford Ranger Raptor, 2004 Toyota 4Runner 2UZ-FE
EH&S
These look great! Do you have the link from eBay or the eBay seller's name? I'm interested in one of these but couldn't find it. Thanks in advance!
RRaptor6G
So it sounds like it doesn’t install with double sided tape and you don’t need to drill holes, just clips, right? I like that. I’ve already gotten one windshield crack from a rock thrown off a dump truck on the freeway, hoping it would cut down on those.
DesertSand
DesertSand
Alberta
Null
-Remove two factory push clips in the front hood weatherstripping
-Install the bug deflector under the weatherstripping,
-Put in the supplied push pin into the weatherstrip hole which goes through the deflector and into the hood.
-Install the Philips screws into the fasteners.
-Install the "w" clips at both ends of the deflector
-clean corner of the hood with supplied wipes
-put on supplied protective film to corners of the hood
-work the clip onto the hood corners. Because of the tight fit, you may want to do one corner "w" clip at a time using warm water. Mine was tight and some of the protective film pushed out of the clip when installing them.
