No forward drive to transmission
Fordmarine
Larry
Virginia
2024 Ford Ranger
24 Ranger XLT with 1669 miles since 4/11/24
I have had issues x4 with losing forward drive on this vehicle, was told by Service the first time no codes and they reset the transmission, since then it has now occurred 3x. Today 5/29 lost forward drive on transmission but no engine loss of power just no response from transmission to go forward this lasted about a minute then the transmission responded and went forward.
Also 2 previous times went over a speed bump and vehicle lost forward drive then responded.
Anybody else having this issue??
jeffers
Jeffrey
Nevada
2024 Ranger FX4, Mk7 GTI
You try the Bronco forums? They've been out for longer.
Fordmarine
Larry
Virginia
2024 Ford Ranger
No, I initially joined the Ranger5g was told I should be in the Ranger6g, I'm new to this forum stuff just disappointed with having issues with a new vehicle with almost 1700 miles on it.
PawnX
PNW
Ranger
Just curious if you know when yours was built? month/week? A lot of the January builds are still on quality holds. I'm wondering if there are more issue's with the early builds.
Fordmarine
Larry
Virginia
2024 Ford Ranger
Build start was February 26, received April 11
danmoochie
dan
florida
retired Sales manager
are you saying you are losing forward gears in 4x2 and 4x4 or only 4x4? and how would you know?
Fordmarine
Larry
Virginia
2024 Ford Ranger
It's a 4x2, I was in drive and the transmission felt like it went into neutral, it held where it was but would not go forward when I gave it gas the engine Rev up but it didn't move then after about a minute it responded and I drove off. Call Ford when I got home.
Kernel___Panic
Philadelphia
Ethical Hacker
This happened to me today in my XLT. Just around 1700 miles.
Fordmarine
Larry
Virginia
2024 Ford Ranger
Let me know what comes of yours, it may be the same issue as mind. We can compare what the dealer did.
DirtDerrick
Nathan
Atlanta
dirtderrick.com
People Person
Mine went out at 500 miles. Ford roadside towed to dealership and dealer installed a new transmission. They couldn’t give me any reason for failure, they just had to send it back to Ford so they could inspect I assume.
Fordmarine
Larry
Virginia
2024 Ford Ranger
Okay thanks, I bet with me talking to service that maybe the case with mind, how long did they have your vehicle for turn around time frame from start to finish are we talking a couple of weeks here.
Thanks
Larry
ivotuk
Ray
North Pole, Alaska
2019 Ranger Lariat
IT
I would demand that they order the transmission first, then swap it out when it arrives. Or, have them give you a loaner. I'm guessing you're making monthly payments? Then they should provide you with a vehicle.
Reactions: PAW
Fordmarine
Larry
Virginia
2024 Ford Ranger
Well update on my 24 Ranger XLT, I was advised by Ford that they will be replacing the transmission on my 1700 miles new truck and send the damage one back to Ford for evaluation to see what caused my issues and if there is a underlieing problem.
Built Ford tough I guess.
Not happy with this we'll see how things procede from here.
Kernel___Panic
Philadelphia
Ethical Hacker
I dropped my Ranger off today at the local Ford dealer to see what they have to say.
