Oil Catch Can. Yes or No?
Beef_Stew
Aaron
2019 Ranger Lariat
Anyone else thinking about installing an oil catch can once they're available? I see it's a pretty popular mod and haven't seen any discussion on it yet.
j0shm1lls
SoCal, USA
www.youtube.com
2016 Focus RS, 2019 Ranger SCrew Lariat FX4 Sport
Vehicle Showcase
Any DI engine can only benefit from a catch can. I'll probably end up adding one, the RS got that treatment.
j0shm1lls
SoCal, USA
www.youtube.com
Vehicle Showcase
Know nothing about this.
Can someone explain?
Direct Injected engines have fuel sprayed directly into the combustion chamber. They don't have the luxury of the fuel washing over the intake valves to keep them clean. Over time they can build up carbon deposits and gum up. The catch can (air oil separator) grabs on to the oil and holds it in the can while still allowing airflow.
Marshal.
Marshal
2019 ford ranger, 1979 Mazda rx7
As soon as one becomes available for the ranger, I too will get ordering and installing one
Beef_Stew
Beef_Stew
Aaron
2019 Ranger Lariat
  • Thread starter
  • Thread Starter
  • #7
How often do you guys drain them? Every oil change or just when their full?
j0shm1lls
SoCal, USA
www.youtube.com
Vehicle Showcase
I'd over check at first, at least once a month until you get a good idea of how much oil your catching. Now I only check my RS every oil change as there's only a few ounces in there.
bandit67
2019 Ranger, 2015 Mustang GT, 2007 Mustang Saleen/Parnelli Jones 302
I plan to get a catch can once there is something available. I have to drain my 5.0L GT (NA) every 1000 miles - I'm getting about 3 oz every thousand miles. I would check it monthly, noting miles, until you have a good feel for how long you can let it go. Let a catch can overflow, and you've got some serious issues.
Bubbabiker
Ford F150 Supercrew FX4
Is this an issue with the 2.3L's? Lot's of debates using the cans for the 2.7L and 3.5L EB's but there hasn't been any hard evidence of valve issues even with high mileage (200k mile +) EB's.
Personally I run a low NOACK oil and not worry about the can.
bandit67
The 3.5L since 2018 added port injection back into the motor, so valve "coking" not an issue. The 2.7L & 2.3L only have direct injection, so coking can be an issue. Over time, buildup can occur, decreasing engine efficiency. Issues start becoming noticeable around 100k miles. Up till then, the slight, slow decrease in power & fuel efficiency my not be as noticeable.
Good quality synthetic oil can help, but all the other byproducts recycling through the intake are still an issue.
PandaMotorworks
Chris
St. Louis
2019 Ranger 2017 Titan 2008 Ford Focus 2014 Ford Fiesta ST
We are talking to radium engineering on getting a catch can made. They have some of the best cans on the market today!
We should receive our ranger next week and we will be test fitting some parts form the RS over to see what all works and doesnt.
I have confirmed our step colder NGK's are the same in the ranger and RS!
Anthony
Moderator
Anthony
Connecticut
2019 Ford Ranger XLT FX4 SCrew
COO
Vehicle Showcase
Good youtube channel run by a Ford tech. He had considerable carbon issues on his valves on his 2.0 Explorer Ecoboost. He recommends going with a catch-can on any Ecoboost / DI engines.
willtech556
Greenwood South Carolina
2000 Toyota Tundra
It makes no sense why Ford didn't go with dual injection on the Ranger like they did with the 2nd generation 3.5. I feel like with this being a 4 banger and the motor always having to work a little harder, carbon buildup is going to be a real issue with these trucks without a catch can installed.
Bubbabiker
Dual injection is slowly being phased in to meet future emission requirements. Adding port injection is not only for cleaning the intake valves but for reducing particulate emissions. Otherwise particulate filters will be required on GDI engines just like diesels.
