Overall Height Ranger Raptor
jordantii
Jordan
Tampa Bay
www.straptacademy.com
2025 RR
Does anyone know if the overall height listed in the 2025 Ranger Raptor Tech. Specs includes the antenna? This is what it says "Overall height 75.9". If it is, I can get the stubby antenna and cram it im my garage.
Flak
25 Ranger Raptor
I think it doesn't, if I remember right. I measured this dozens of times pulling the truck in a few inches more each time and praying, have to clear an I beam that's low in my garage. I actually had to get a stubby jr because antenna could actually hit part of my garage door if I was exactly centered.
midnight270
NNJ
2025 Ranger Raptor CGM
My single car garage door is 80 inches tall. The truck fits with a stubby antenna. It would rub the door going in with the stock antenna.
Glisch
Houston, Tx
This seems spot on. Just did a rough measurement of mine, its ~75 inches without the antenna. Then the factory antenna sticks up 5-6 inches above that.
Glisch
Houston, Tx
75 inches to the fin? I know it's a rough guess.
Yeah, top of fin is right about 75in. I just held a level across the fin and dropped a tape measure down to the floor to get the measurement. Not perfect, but close enough. As long as the stubby antenna isn't bigger than 3 inches or so, I think you will fit. (it angles backward, and starts about an inch below the fin)
jordantii
jordantii
Jordan
Tampa Bay
2025 RR
Cool, thanks. I'll have the stubby tomorrow and I'll report back. I hope it fits. Lol
Flak
25 Ranger Raptor
Measured it again, my I-beam is 77.3" tall and the truck fits under, looks like the shark fin would but not the antenna.
Flak
25 Ranger Raptor
Oh this is promising info. So do you think the stubby will work?
With Stubby Jr (I think thats the smallest one) it looks like its maaaaybe kissing 78" ish. I mean the problem is when you're getting down to those numbers angle of approach from driveway onto garage slab, tire pressure, etc... shaving mms off your clearance at that point
You might be able to squeak it by with the Jr at 77, I'm eyeballing it because my truck doesn't go in that far. You should be fine with the truck body, just pull it in slowly and check IMO.
jordantii
jordantii
Jordan
Tampa Bay
2025 RR
Yeah it’s gonna be tight and I have the Jr. arriving tomorrow. I measured from the garage slab so we shall see. Fingers crossed
Tuna
Germany
Ranger Raptor (EU)
Aeronautical Engineer
Not sure it really helps, but Ford´s Body and Equipment Mounting Manual (BEMM) chapter 1.11.9 indicates a height of 1926mm (which equals 75,83") for the Ranger Raptor Base Kerb Weight, measured at antenna base.
Of course it also says dimensions are subject to manufacturing tolerances and refer to minimum specification models and do not include additional equipment.
Ans height dimensions are for guidance only...
jordantii
jordantii
Jordan
Tampa Bay
2025 RR
Yeah, thats what the tech specs says as well. I'll try it and see. If it does not fit, i'm gonna move...
Chuck2001
Montreal, Canada
25 RR, 24 Golf R
Stock RR with stubby antenna, I fit eveywhere, even downtown interior parking that says 1.95m maximum. It's tight ; first time I had my head outside the window like a dog to take a good look.
Sorry I'm metric...I don't measure stuff in thumb's width
