Powerswitch/fuse/bus bar mounting solutions
Sikkboy
Justin
Arizona
Mustang GT
Before I build something does anyone know of any pre built options similar to (pirate camp co) that are confirmed to be available to ship to the US?
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
Before I ordered the arb dual battery kit from bpt motosports in Australia to Canada, I just used the included double sided tape from Diode Dynamics to mount my D switch to the top of the fuse box and still be able to open the lid. then I moved it to a simple sheet plate mount I made to go on the battery hold down.
Ford Ranger Powerswitch/fuse/bus bar mounting solutions 20250606_204234
Ford Ranger Powerswitch/fuse/bus bar mounting solutions 20250802_180922
Ford Ranger Powerswitch/fuse/bus bar mounting solutions 20250723_183137
Sauce
Northeast
2025 Ranger XLT FX4
This is what you want - specifically built for the Powerswitch.
https://www.powertrays.com/collections/garmin/products/garmin-powertray-standoff
I mounted it on top of the fusebox cover. I bought a Blue Sea fuse block and ground block. If I did it again, I'd ask powertrays specifically which Blue Sea fuse block and ground block models they used to design the tray because I wound up having to drill some holes to make mine fit (they were slightly different models that didn't align with the hole spacing) - easy enough though. It is an extremely clean solution if you are tidy with your wiring. I did a DIY before I got this and wasn't happy with it.
I think Blaze Offroad also offers a bracket, but I think it comes with some other parts / wiring and its more expensive with a longer lead-time to order.
To add - Ive seen a lot of people use the powerswitch without fuses for each channel. I think its good practice to have a fuse block (cleanest) or inline fuses (also safe) sized to the needs of each channel since the channels themselves aren't otherwise fused (beyond the high amperage fuse upstream of the powerswitch). Each channel has 30 amps, which is way overkill for things like lights or switches.
Sikkboy
Justin
Arizona
Mustang GT
And photos after you swapped over to the power tray?
Sikkboy
Justin
Arizona
Mustang GT
No rush, thanks for the feedback
Sauce
Northeast
2025 Ranger XLT FX4
Unfortunately the truck is at my summer home, and I won't be there again for a couple months. Don't want to keep you waiting. I can assure you that its very clean and mounts on top of the fusebox cover easily. I just drilled a couple holes in the cover, bolted through it and then put some sealant around the holes just in case. Need to use small nuts though since theres not a lot of room in the fusebox for them. Its a little cumbersome when you need to take the fusebox cover off (with all the wires attached), but thats pretty rare.
ryanO
Ryan
2025 RangerXLT
Sales
How do you like the dual battery from ARB? Does it charge off the alternator? Any issues?
