Product Report - TripleAliners Center Console Insert
got3fords
James
Central Va.
I recently received my center console insert/organizer for my Raptor. I wasn't really looking for one because an upper shelf came with my truck. But I got this for the cost of posting this review.
First, it looks cool. The trim color matches the Raptor red trim. Although it's a moot point unless the armrest is open. The color is determined by the rubber inserts.
This organizer is two pieces, giving your center console three levels of storage. So I assume you put your less accessed stuff at the bottom, the most frequently accessed stuff on the top. In my case, the top part didn't quite sit flush in the lower part when in the truck. On the bench it works fine. I actually couldn't close the armrest until I forced it flush. It's been fine since but the two pieces are still not quite flush.
The multiple sections make it easier to keep things tidy and within reach. And the corner notch allow access to the 12V port. Overall the build quality is good, aside from the minor fitment issue. For the listed price, I would highly recommend it. If your truck came with nothing but a deep hole, you will like this.
Two-Layer Console Organizer
https://www.amazon.com/dp/B0DBVBZM3G
Thanks TripleAliners.
Before:
Ford Ranger Product Report - TripleAliners Center Console Insert 1790686849549-dr
After, top level. You can see it sticks up a little on passenger side:
Ford Ranger Product Report - TripleAliners Center Console Insert 1790686902826-2z
After, mid level:
Ford Ranger Product Report - TripleAliners Center Console Insert 1790686934989-lr
Ford Ranger Product Report - TripleAliners Center Console Insert 1790687221253-lq
Ford Ranger Product Report - TripleAliners Center Console Insert 1790687297487-rg
Tripleliners is selling the Muslogy product.:LOL:
They might be the same company but who knows.
Crapblaster
What kind of balls are those for your Byrna?
got3fords
got3fords
James
Central Va.
got3fords
got3fords
James
Central Va.
Mix of kinetic and chemical. Glock is in a cabled lockbox in the rear. There's a lot of theft from vehicles around where I work.
STEVE_K
Snohomish, WA
For those questioning the cost.... Depending on the type of tooling used, the molds are probably run $10k - $20k, then cost of the injection molding machine from initial purchase and on going maintenance costs, then the purchase/lease of the building to place that machine which can be larger than our trucks so it can do both small and large parts because they need to be able to do a wide variety of parts to keep that thing running constantly to recoup the purchase and maintenance fees, cost of the operators to run it, shipping, and so on.
And yes, probably 2 or more companies selling these as anything running through China customs requires drawings of the products to be submitted... Which sadly leaks out and gets duplicated elsewhere, or someone at the manufacturing location is running a backroom operation and selling it under another name with leftover materials.
Thought I would toss that out there since I worked in electronics design and manufacturing for many years and spent quite a bit of time in the factories in China.
skhale69
Oxford, MS
2018 F150 FX4 Lariat Supercrew, 2024 Ranger Raptor
Retired Firefighter
I got a set for my RR a week ago and was impressed with the good fit in the console. I felt like it was a pretty good value.
Before:
After, mid level:
got3fords
got3fords
James
Central Va.
Very true. I always cringed when we outsourced stuff to China. Also, the rubber liners in the console trays are top quality and the custom color surely adds to the cost.
