Question about factory lined bed
Phlfwd22
Matthew
Tampa
Firefighter
For the trucks that come factory spray in lined, did they cover all of the mounting holes? For example if you want to move the front tie down hooks up or add a bed extender, are the holes still there or do you have to basically guess as to where they’re at and drill into the liner?
Dry0atmeal
on mine they did the whole shabang... mounts and all...
Phlfwd22
Matthew
Tampa
Firefighter
hmm. I’m wondering if I should change my order then and do without the spray in liner for now until I get the bed configured how I want
Phlfwd22
Matthew
Tampa
Firefighter
This is a dumb question but CAN I move the tie downs and/or add more tie downs as well as a bed extender with spray in liner?
Dry0atmeal
A shop that does SIB would probably be able to remove the tiedowns and plugs...depending on when your order was placed it may or may not be to late to change things...good luck
Hootbro
Delaware
2024 Ranger STX 4X4
I have the factory spray in liner. For the bed extender and any other accessory mount holes, they mask off and remove after spray to leave clean holes
Phlfwd22
Matthew
Tampa
Firefighter
I have the factory spray in liner. For the bed extender and any other accessory mount hole, they mask off and remove after spray to leave clean holes
perfect - thank you!
EggsG6
Windsor
2024 Ranger XLT 2.7L
For the factory bed spray guys, did they spray the area from bottom of tailgate and very back area of bed?
LineX guys that sprayed my truck said the 2024 Ranger tailgate is more complicated to remove now and spray.
Or was he lazy?
Ford Ranger Question about factory lined bed IMG_5263
Ford Ranger Question about factory lined bed IMG_5264
fordtrks4ever
Perkiomenville, Pa
My LineX looks the same
jedadiah
Jed
Kentucky
Or was he lazy?
Because of the "easy lift" spring, the tailgate is much harder to remove than in the past. It's not a quick job. You have to unbolt it
EggsG6
Windsor
Thank you for the extra info. Is there any other product I can use in this area or should I not be concerned?
