YukonRanger
YukonRanger
Yukon
I have now added A Rim weight calculator which will automatically select the appropriate rim for the corresponding tire, then update the weight of the Entire wheel package in the final column
To use....just go ahead and enter the appropriate rim weights for your dream wheels in the top input area
Ford Ranger Ranger 6G Wheel Calculator 1764309266005-6l
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
I did get a set of 24 Bronco Big Bend OEM takeoff rims/tires, so I'm going to try out the 255/75/R17 Bridgestone Dueler's that I measured at 32" at 35psi unloaded. They should be within a couple lbs from the 255/70/r17 OEM Goodyear Wranglers
YukonRanger
YukonRanger
Yukon
Some people were complaining about not being able to edit and sort
So I completely changed the setup and added instructions to clarify
You must now go to
File > Make a copy
before you can edit anything
Ford Ranger Ranger 6G Wheel Calculator 1764326031135-xt
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
Here's another data point, I weighed 5 2024 Bronco Big Bend 6 spoke grey wheels and they are 22lbs each with valves and wheel weights installed. Perhaps this is the lightest OEM rim option?
Ford Ranger Ranger 6G Wheel Calculator Screenshot_20251201-175119
YukonRanger
YukonRanger
Yukon
Good to know. What is the offset on these?
If people want to gather the data on thier favourite rims...I will add it to the calculator.
For now you can just put 22lbs in the 17" Rim weight field and it will do the math for you
Cheers bud.
YukonRanger
YukonRanger
Yukon
Now updated to V1.4 with a rim selector!!!!
Need help with rim sizes and weights!!!
Reply with your favourite rim in the following format:
(Brand) (model) (Diameter)𝕏(Width) (offset) (Weight)
For Example
Enkei RPT1 17x9 +024
Ford OEM Ranger Lariat 17x8 +5532
Ford OEM Ranger Raptor 17x8.5 +5528.3
Ford OEM Ranger Raptor BL 17x8.5 +5536.4
Ford OEM Ranger XL 17x7.5 +55 25
Ford OEM Ranger XLT 17x7.5 +5531
RTR EVO 6 17x9 +024.4
RTR EVO 6 17x9 +3022.6
Vision Warrior 17x8.5 +25 22.35
Vossen HF6-4 17x8.5 +3526
Vossen HFX-1 17x8.5 +3526
Enjoy!!!
YukonRanger
YukonRanger
Yukon
Now updated to V1.5 with portal support and a truck selector!!!
You can now compare all data to the OEM setup for each ranger trim, without or without portals. This allows you to estimate the drive train losses or gains depending on your specific setup.
There are also 3 predefined views which you can select by going to
Data -> Change view
  • All tires
  • Light 33's and up
  • Light 35's and up
  • Light 37 and up
This displays tire combos which are lighter than or the same weight as the factory ranger raptor wheel package. Currently there are only two 37" tire combos which make the cut and then only if you use 1K a pop ultralight Rays wheels!
Enjoy.
Ford Ranger Ranger 6G Wheel Calculator 1764881040538-5k
