Ranger Raptor and DTC B1578:78
Hande
Hannu
Estonia
Business Owner
This Ranger Raptor has been part of rear camera recall, but "Reverse Brake Assist Not Available" has never really disappeared.
So after multiple visits to Ford dealer, I tried to get rid of B1578 DTC by myself.
I am trying to do Forscan 360 camera calibration on a parking lot, every time it says "100% calibrated" for all 4 cameras, but at the last moment "calibration failed".
What i am missing, is there something else that must be done?
Hande
Hannu
Estonia
Business Owner
I know, just would not like to drive 120 miles to the next dealer :frown:
Better to do it by myself,if it is doable with Forscan.
rugedraw
Javier
Miami, FL
Auto Sales
Is the IPMA rendering the images correctly? If so, you can ignore the code, tbh. I can tell you that while FORScan is capable of calibrating the 360 cams, FDRS is better at it.
If the cameras look right and all you want to do is get rid of the code, go here in the IPMA:
706-26-19
xxxx 8xxxx xxxx
If you do not have an 8 there, write the 8, reboot the IPMA and clear codes. That bit is what tells the IPMA it is calibrated and it should make the code go away.
Ford Ranger Ranger Raptor and DTC B1578:78 1785436873383-2q
Hande
Hannu
Estonia
Business Owner
706-26-19
xxxx 8xxxx xxxx
Thank you!! Works perfectly, even reverse brake assist works again. A very important feature when the lady is dricing...
How do you guys know this kind of stuff? :shock:
rugedraw
Javier
Miami, FL
Auto Sales
Happy to hear! This particular bit I learned from one of the gurus over on the F150 forum, but a lot of it I've learned from just FAFO. 🤣
