Ranger Raptor and DTC B1578:78
Hande
Hannu
Estonia
Business Owner
This Ranger Raptor has been part of rear camera recall, but "Reverse Brake Assist Not Available" has never really disappeared.
So after multiple visits to Ford dealer, I tried to get rid of B1578 DTC by myself.
I am trying to do Forscan 360 camera calibration on a parking lot, every time it says "100% calibrated" for all 4 cameras, but at the last moment "calibration failed".
What i am missing, is there something else that must be done?
Hande
Hannu
Estonia
Business Owner
I know, just would not like to drive 120 miles to the next dealer :frown:
Better to do it by myself,if it is doable with Forscan.
rugedraw
Javier
Miami, FL
2021 Ford F150; 2023 Bronco Sport; 1991 Mustang 5.0 coupe.
Auto Sales
Is the IPMA rendering the images correctly? If so, you can ignore the code, tbh. I can tell you that while FORScan is capable of calibrating the 360 cams, FDRS is better at it.
If the cameras look right and all you want to do is get rid of the code, go here in the IPMA:
706-26-19
xxxx 8xxxx xxxx
If you do not have an 8 there, write the 8, reboot the IPMA and clear codes. That bit is what tells the IPMA it is calibrated and it should make the code go away.
Ford Ranger Ranger Raptor and DTC B1578:78 1785436873383-2q
Hande
Hannu
Estonia
Business Owner
706-26-19
xxxx 8xxxx xxxx
Thank you!! Works perfectly, even reverse brake assist works again. A very important feature when the lady is dricing...
How do you guys know this kind of stuff? :shock:
rugedraw
Javier
Miami, FL
Auto Sales
Happy to hear! This particular bit I learned from one of the gurus over on the F150 forum, but a lot of it I've learned from just FAFO. 🤣
cfm56doc
Tampa
2023 Bronco Sas (Hers), 2024 Ranger Raptor (His)
Jet engine field service rep
706-26-19
xxxx 8xxxx xxxx
I just tried this as I have the B1578 DTC and when I try to write the "8" as posted above, it tells me it is an incorrect checksum. I say write it anyway, but when I open the file back up, it writes it back to a "0".
To be clear, I am at code line 706-26-19 and my as built values are FF16-0000-0061. I replaced the first zero in middle series and that is when it tells me incorrect checksum when I say write all.
rugedraw
Javier
Miami, FL
Auto Sales
Did you try running the actual calibration first? Are your 360 cam view stitched together nicely with nothing overlapping or off?
cfm56doc
Tampa
I did not try the calibration as I thought i read you need to drive like 10 miles on a straight road.
As for the images overlapping or missing, I will have to look again when I get home.
But if 8 is an invalid checksum I do not see where that would matter.
pablo94sc
Focus
I believe you can delete the last 4 digits when you change the other to 8, and it will generate the new checksum value. You'll want to read through the forscan thread to verify that.
rugedraw
Javier
Miami, FL
Auto Sales
Are you talking about the generic warning that FORScan gives you before you make any config changes? If you change a value, the checksum will always be invalid, but FORScan will correct the checksum (last two bits on code on that line) by itself.
Entering that 8 there is to force the IPMA into knowing it is calibrated and should not be used if the IPMA actually needs calibration. If it is not letting you write that change, then I would recommend running the calibration procedure first and yes, the process will require driving with the laptop hooked up to it either on a straight road to calibrate the lane keep assist camera on the windshield, or in an empty parking lot with well painted parking spaces if you are trying to calibrate the 360 cams.
If your 360 cam images are fine and your lane centering works fine and you still have that code in the background, you can just ignore it.
cfm56doc
Tampa
I do not care if the code stays, just wish that stupid back up assist not available message would disappear.
Will try your recommendations later this week.
rugedraw
Javier
Miami, FL
Auto Sales
Do you have back up assist disabled in your settings, or do you have it enabled but get that message when you put it in reverse?
In my case, I have it turned off because I hate it. However, every time I put it in reverse, it gives me the message that it is not available to let me know that I'm on my own.
cfm56doc
Tampa
I will have to verify, but think it is grayed out so I cannot enable or disable it.
Btw I have only had my 24 RR about 2.5 weeks, so still trying to learn about it.
rugedraw
Javier
Miami, FL
Auto Sales
Ok so that may be due to a configuration error. Message me the VIN and I can poke around to see if I see anything helpful.
