Raptor side steps ? Anyone removed them?
Dunn Rj
Ron
Gary, TX
2004 Ranger Raptor
Is there a way to lower the side steps. My wife and I are both short and have to pull up into the cab….I like the step bu would like to lower them??
DvD
Overlander
Spain
Ford Ranger Raptor 2024 diesel
Sailor
Hi All,
I removed the side steps but I noticed that on the passenger side there are some cables exposed and at risk to be cut. I'm thing about bush areas and things like that...
Not sure what these wiring are for either. My Raptor is the diesel version (EU) without any suspension adjustment. Does anyone have notice the same thing and had any issue?
Ford Ranger Raptor side steps ? Anyone removed them? 1
Ford Ranger Raptor side steps ? Anyone removed them? 3
Ford Ranger Raptor side steps ? Anyone removed them? 20250111_181313
Ford Ranger Raptor side steps ? Anyone removed them? 4
pappacrunch
Kevin
San Diego
1955 Ford F100
I replaced mine with sliders from Goat Fabrications. Easier to get in an out for me 6'3" and the copilot 5'3". Here is a pic with the factory running board off and with the Goat Fab slider on. The sliders keep the rocks off and the shopping carts away.
Ford Ranger Raptor side steps ? Anyone removed them? IMG_6063
Ford Ranger Raptor side steps ? Anyone removed them? IMG_6065
DvD
Overlander
Spain
Sailor
Thanks for the info, looks good.
I have to see if there's something in Europe similar to this
DvD
Overlander
Spain
Sailor
I have to see if there's something in Europe similar to this, I guess are bolted to the chasis directly.
Fawnbuster
Indiana
ryanO
Ryan
2025 RangerXLT
Sales
I like my side steps for body protection, but for me they seem to be more in the way of getting in and out quickly then they are helpful.
I think they are too high off the ground and seem to put me up way too high and then I have to crawl down into the truck.
Same thing happened with my Bronco.
Except with the 35s it was tall enough I did want something so I pulled the slider steps off the Bronco and installed power steps, which were about perfect for it.
I am thinking I don't really need anything for getting into the Ranger easily and quickly even with my upgraded 34s, which are really only 33.5.
I seem to recall a thread on here where someone posted pictures with the steps off his new Ranger Raptor, but I can't seem to find it.
I was also thinking there was talk of some cladding that be stuck on the belly of the truck to get some added paint protections with the steps gone.
Would love to see more pics without steps and to hear others thoughts on this, plus if anyone knew anything about the protective cladding for the belly of the trucks I would love to know more about it and where to get it.
What I don't like is sliding across the seat bolstering when getting in or out. That will 100% break down the bolstering/side of the seat more quickly than necessary. I'm gonna leave mine on so I can be easier on the sides of the seat.
I am sure that is true.
I did leave the steps on my 25 model, not worried about the seats.
Truth be told the seats could stand to have a little extra foam added to them anyway.
I am mainly leaving them on my 25, due to all the rock damage I am getting on the back fenders.
Even with PPF, mud flaps, I am still seeing significant damage from not having them on there.
The damage is already done, so I am leaving them off my 2024 but in effort to protect my 2025 RR I have left them on and did lower vinyl wrap for added protection and aesthetics.
Ford Ranger Raptor side steps ? Anyone removed them? {filename}
Pics of the back fenders on my 24 model with 10K miles running without the steps.
Bt_okst
BT
Ok/Colo
Lots have done it, but stay off any gravel roads or parking lots. Factory boards are only thing keeping sides of truck from being all chewed up from gravel. Only reason I've kept them on mine. Even with mudflaps the gravel pings against bottom of the boards.
Bt_okst
BT
Ok/Colo
Yep. Boards serve as protection for truck more than anything else.
Lots have fone it, but stay off any gravel. Factory boards are only thing keeping sides of truck from being all chewed up from gravel. Only reason ive kept them on. Even with mudflaps the gravel pings against bottom of the boards.
I actually live on a paved road with a paved driveway and only occasionally go off road or travel on gravel roads.
The gravel roads I built around my property that I do drive on, is typically just more idling around at 5-10 mph, not really typical road speeds. Nothing much is getting kicked up at 5mph. But some of the smaller gravel rocks do get stuck in the tread and will typically eject at highway speeds. I am sure that is where some of damage has come from, they also sand the bridges and intersections in the winters around here. I am thinking that is where the bulk of the damage has come from.
I can't imagine how beat up those fenders would be if I lived on gravel road like I did when I was growing up on our family farm back in the 80s and 90s. LOL
waffleso_0
Oakland California
24 Ranger XLT 2.7L V6
I found the underbody protective cladding.
It is a Ford accessory.
SKU: VR1WZ1613208B
RANGER 2024 BLACK TEXTURED EXTERIOR TRIM BODY ARMOUR ROCKER PANEL PROTECTION FOR SUPERCREW
$289.00
ABOUT THIS PRODUCT
Details
Covers the door sill and rocker area under doors.
  • Helps to provide protection from road debris and scratches
  • Hides existing scratches and damage
FITS THESE VEHICLE
Ford Ranger 2024
TECHNICAL SPECIFICATIONS
Catalogue: FLA
Brand: Bushwacker
seem to be on back-order but found a site that has them slightly cheaper: https://s1partscenter.com/brands/ford/accessories/exterior/trim-kits/vr1wz1613208b
I see you have an XLT, which is good, since these didn't say they are not for Raptor at least not when I ordered mine. But they are not really a perfect fit for the front fenders of a Raptor.
The rest is the same but thought it worth mentioning that it was a bear to get them mounted on my 2024 RR back in spring 2024.
