Rear differential LS additive?
Afsigma21
OH
2024 FX4 Lariat v6
Air Force
RB205
BB
Denver
XJ
Lockers aren't limited slips. You don't need the additive but it also doesn't really hurt if you use the Valvoline with it already included.
Run the gear weight you want. Dana recommends 75w140 for these M220 Advantek axles. That's what I'm planning to run; Ford just recommends lighter oil for better mileage.
Afsigma21
OH
2024 FX4 Lariat v6
Air Force
OK, Using same thread for a newish topic related.
Looks like we have Dana M220 which Ford calls for 75w85, but Dana calls for 75w140 for HD situations like towing.
Prepping my truck to tow a camper from Ohio to Alaska and back. Differential fluid before the trip is a 100% item, I was going to go to 75w90 Valvoline, but now I am considering 75w140 since I will tow approx 10k miles on the trip.
Replacing upon my return with 75w90.
I would love to hear some thoughts on the 75w140?
MasterCylinder
Jay
Retired, FF, CET, Mechanic
The debate on 85/90 weights verses 140 has been going on since it's inception. The main reason for the lighter gear oils was Fuel mileage gains however slight to meet government standards.
Little information for you to ponder on.
GradeSAE 75W90SAE 75w140
Density 15 C, g/cm3, ASTM D40520.860.89
Flash Point, Cleveland Open Cup, °C, ASTM D92210203
Kinematic Viscosity 100 C, %, ASTM D44515.725
Kinematic Viscosity 40 C, mm2/s, ASTM D445115182
Pour Point, °C, ASTM D97-45-45
Viscosity Index, ASTM D2270144170
The flow is measured through a viscometer at a certain temperature according the ATSM standards.
All rear axles gear teeth are setup the same with a certain degree of what is called back lash so that there is no whine from being too tight and space for the gear oil to get in between and lubricate and protect the surfaces form heat and wear. The lighter gear oils weren't commonly used until the late 90's. All gear oils contain what is called extreme pressure additives for their intended use. 90W gear oil is almost the same as 50W motor oil viscosity wise in testing. :like:
Afsigma21
OH
2024 FX4 Lariat v6
Air Force
" The debate on [insert any oil/fluid/additive] has been going on since it's inception "
SO TRUE
Im leaning towards the 140 just for the trip then go back to 90.
MasterCylinder
Jay
SO TRUE
Just as a note, get yourself a decent Infrared thermometer. Check your temps under normal conditions and then when towing. Keep in mind today's synthetics adds a bit of protection from heat over conventional and from experience anything over 250F in my book is getting into the yellow caution zone for any gear lubricants. If changing it makes you more comfortable by all means be comfortable, it's your ride! A Electronic locker normally is not a LSD because it has the Electronic lock. :sunglasses:
