Rear seat back latch
gmarcucio
Glenn
Upstate New York
24 Toyota GR Supra MT, 24 Corvette Z06, 24 Ford Ranger XLT, 22 Mini Cooper SE
Retired High School Auto Tech Teacher
Definitely should be covered under warranty. Mine was including the damage to the seat back. Mine now closes normally. I don't have to do anything special like gmarcucio is suggesting.
You are absolutely correct, I shouldn't have to do anything special like I mentioned to get the seat to latch because of a faulty part or poor design. What was done under warranty for yours to work properly? Any new parts, latch, striker, etc.? Do you happen to have a copy of the repair order from the dealership you can share with us describing what they did to fix the issue? Thanks!
T-Rev
Not sure where I put the repair order. No new parts, they said they adjusted the latch and also a bracket was interfering. Based on the picture I shared in this thread previously; it might have been one of the brackets circled.
Ford Ranger Rear seat back latch 1738352244692-qd
Awirez
Sure looks like the child seat anchor point left an impression on the back of your seat. It sounds like a widespread issue.
It has a logged complaint with NHTSA. Also there is a SSM from Ford. Dealer replacement of the latch assembly for the win. Link to SSM here, 2022 Maverick.
When/If I take delivery months from now, I'll be checking this for sure.
Ford Ranger Rear seat back latch 1738355978389-h5
gmarcucio
Glenn
Upstate New York
I removed both of those seatbelt tether brackets to see if they were getting in the way but it didn't make any difference. Now that I see here the fix for the issue the dealer will perform I'll bring it to them and have them replace the latch.
T-Rev
I remember the service writer saying "bracket" but the description of the work says, "found the head rest hitting a bolt on a box on back cab panel". That sounds more like it was the subwoofer.
Ford Ranger Rear seat back latch 20250131_185433
jlanz
2024 Ford Ranger XLT
I added lock washers under the catch. That fixed it. But I shouldn't have to do that on a new truck. :)
