Rear View Mirror Power for Radar Detector
Shelpdogg
Apex, NC
IT Manager
Searched for this and I see a few that are specific to the Ranger Raptor, but not the standard Ranger FX4.
Does anyone know which connector I can tap into for a radar detector (in the shroud above the rear view)?
Is this the same as the RR??
Thanks in advance.
Shelpdogg
Shelpdogg
Apex, NC
IT Manager
nothing?? Nobody else has done this yet?
Shelpdogg
Shelpdogg
Apex, NC
IT Manager
never mind...I figured it out. :thumbsup:
SoutheastRangerRaptor
I tied in to the fusebox in the cab, driver's side under the steering wheel using a fuse bridge and routing the wire up the left side of the windshield behind the plastic and along the top of windshield to the mirror. Works like a champ when truck is turned on.
jrRaptor
Maize, KS
OH3Cobra
JP
Indy
Sales
There is another thread that shows how to use micro taps into the power behind the rear view mirror. I did that and am very happy with the results. blendmount has the information and taps. I went with a longer cord. Needed.
gdub
SoCal
2002 Ranger FX4
Aerospace Engineer.
Are there still police that use radar? I stopped using my radar detector a few years ago because the only alarms I got were false alarms. I thought speeding enforcement had switched over to laser.
jrRaptor
Maize, KS
Highly dependent on your region. Small town and county sheriff deputies in my location run radar 100% when they're driving and they are easy to pick up early. Same with State Troopers. But if they're stationary, sitting in speed traps, they'll get you with laser.
Shelpdogg
Shelpdogg
Apex, NC
IT Manager
I'm not sure on the RR differences to FX4 but pull the shroud and check the wiring and compare to mine:
https://www.ranger6g.com/forum/thre...ap-for-detector-or-dash-cam.8696/#post-158831
If wiring looks the same, get a mirror tap and call it a day. If not, then you could just get a fuse tap and plug into the fuse box under the steering wheel/dash.
jrRaptor...I used that exact same plug. That was the thread I had seen and was hoping it was the same connection.....it was. Thanks
Jeffola
Southwest Florida
Business Development
I did the same as this post, worked great. I wonder if the Aus version USB port is available and works with our wiring?
