Ride Quality Inconsistencies RR
RaRaRaptor
what mode were you in?
Normal on highway switched to offroad after pulling off and at a complete stope, then started in offroad when leaving.
ColeTrainsRR
Cole
Minnesota
E-Tec 3
dealer had my air pressure set at 40-41psi. i dropped it down to 35 and when they are warmed up they run around 38psi and that seemed to help a bit. mine only has 1100 miles but i too have noticed the ride is inconsistent and can't feel much change with ride settings
RaRaRaptor
so I sorta discovered something today.
whatever mode it is in during startup seems to hold. or atleast whatever damper option is picked immediately after start.
if you set the R mode to whatever damper you want then the next time you turn it on double click the button almost immediately after a full start (remote start doesn't seem to matter, foot on brake im calling full start) it seems to hold that mode even if switched later. also returning to a mode immediately at start also seems to do this.
testing this with offroad and sport seemed to show the most difference, and by a lot. sport feels locked in on highway and offroad super loose and floaty almost.
BigAir
Montana
I wasn't impressed at all with the small bump compliance when we first bought ours. Checked tire pressure and it was set at 45 psi. Lowered it to 36 front and 35 rear, and that made a noticeable improvement. I still wish it were slightly softer.
jacksdad
North Central WA
Do you think getting a true 35” tire would get you to a point where you’re satisfied?
