RR BCM reverse wire tap
RaptrJr
FL
Looking to tap into the reverse wire on the BCM. Does anyone know which wire this is? I’m leaning to think it’s the same as the F150 based on some diagrams I’ve seen. White wire in the C2280C connector on the BCM. Does anyone have any more info on this? It’s in really tight spot under the dash and is hard to see the wires.
RaptrJr
RaptrJr
FL
Wiring diagrams says it is a GREEN-BROWN (GN-BN) coming off pin 11 of connector C2280C of the BCM.
Exactly what I was looking for. Thank you.
scrappyisbe
james
iowa
24 RR
why not just tap into the wire in the 7 pin trailer plug?
RaptrJr
RaptrJr
FL
Its for a 3rd brake light and the wires are running in the cab and forward.
