RTR Tech 6 17x9 +30 Offset
Stoogey
Stuart
Hampshire, UK
2023 Ranger Raptor 3.0L V6
Hi all, my RTR Tech 6 17x9 Wheels have arrived. Have ordered some General Grabbers 285 70 R17 to wrap them in.
However, just though I’d seek some advice in that the stock wheels are 8.5 not 9’, assuming I shouldn’t have any issues with this tyre size?
Thanks in advance
Ford Ranger RTR Tech 6 17x9 +30 Offset IMG_1064
Ford Ranger RTR Tech 6 17x9 +30 Offset IMG_3514
Daweism
Austin, TX
Yes, the 17x9 will be fine on stock tire size. I run the RTR EVO 6 17x9 30mm. Basically these offer the same stance of 17x8.5 25mm in terms of "poke" if you factor in that extra half inch of wheel, so 30mm+the extra 1/4th inch of wheel on the outside.
Ford Ranger RTR Tech 6 17x9 +30 Offset 20250517_102322
Ford Ranger RTR Tech 6 17x9 +30 Offset 20250517_102315
Ford Ranger RTR Tech 6 17x9 +30 Offset 20250524_182607
Ford Ranger RTR Tech 6 17x9 +30 Offset 20250524_182551
Stoogey
Stoogey
Stuart
Hampshire, UK
Thanks mate, bang on the info I was after!
loving the blue too ??
Daweism
Austin, TX
Are you guys buying 5 wheels to use one as a spare?
Personally no, not worth it sitting under the truck getting battered for a flat, the original will do just fine.
I am. The spare doesn't get battered because it's mounted face up. 99% of the debris hits inside of the wheel. If you're kick up that much stuff, you're spare will be taking less damage than the 4 you have mounted and driving on anyways.
Also using a 5 tire rotation will increase the life of the tires and you won't have an old ass spare tire when you're on the 2nd and 3rd set of tires later on.
Stoogey
Stoogey
Stuart
Hampshire, UK
it’s a fair point, each to their own I guess
boraxman
Santa Clarita, Ca. USA
Been shopping wheels since I bought my truck. Think Im going with black EVO 6 when they get back in stock.
Daweism
Austin, TX
Excellent choice, they are 22.5lbs compared to the roughly 37lb stock beadlocks. You'll notice the weight savings.
Stoogey
Stoogey
Stuart
Hampshire, UK
have you got the Ford beadlocks on your one? Haven’t seen one in the UK with them on!
boraxman
Have the beadlock capable wheels as they came stock but no beadlock rings.
Got them fitted, some difference to the way it drives. Much smoother, lighter feeling
Like the rear light bar location. Here it wouldn't be allowed as it would block the plate.
Daweism
Austin, TX
You can close this gap on that trim piece by giving it a nice pound and it'll seat properly. Mine came like that from delivery and I just smacked it and it was flush.
Ford Ranger RTR Tech 6 17x9 +30 Offset 1749245490329-5u
Stoogey
Stoogey
Stuart
Hampshire, UK
That bits my fault, tried lifting them up to help waterproof the bed - ended up permanently bending it. Need some new caps so I can finally get it more watertight. These new rangers are shite for that, my old shape ones were always much better.
