Secondary Speedometer and Speed Limiter
NM Mike
New Mexico
I believe the copilot 360 feature is part of the technology package currently. Not sure if its been that way since inception.
bigb
bigb
Tucson
2025 Ranger 2.7
So today I went into the menu from the steering wheel and selected the secondary speedometer. When I did, the primary speedometer switched to KPH and the secondary to MPH. Hoping this will work on the speed limiter. I'll report back after the trip.
bigb
bigb
Tucson
2025 Ranger 2.7
It worked, sorta. The only issue is that the camera did not recognize every speed limit sign. Some were badly faded so I can understand not seeing those but others were like new and it still missed them. I would estimate it saw only about half of them. It could also be due to the fact that the system uses information from a database which may be incomplete in some areas. Also, I'm not sure if all of the signs said km/h on them, some of them may have just had the number with the red circle, not sure if that makes a difference.
Ford Ranger Secondary Speedometer and Speed Limiter speed limit
