SignatureLux bi led fog lights review and pictures
ntbruncie
Nick
Phoenix Arizona
Those of you interested in replacing your factory fog lights with a set of SignatureLux bi beam leds here is a few pictures of how well they work.
Things to note:
To turn the fog lights between high beam and low beam. You need to turn the fogs off and then turn the fogs on. Then to go back to low beams do the same thing again turn them off turn them on.
I have also noticed that if you have the fog light switch off and turn the steering wheel, the fog light in the direction you are turning will turn on. Which means when you actually turn fogs on most likely one side will be on high beam and the other side on low beam. To correct this you turn the fog lights off turn the steering wheel in One Direction and back to center and then turn on the fog lights on with the switch. This should set both fog lights back to either high or low.
Installation :
As far as installation goes, it’s very easy. It is a true plug-in play kit. For those of you that are leveled on larger tires like myself you may have to remove the front wheel and tire to be able to gain access to drop the front half of the inner wheel splash guard. The only issues I had with install was that they sent me the wrong fog lights. I ordered the yellow set and when I received the box, it was marked as yellow, but once they were installed and activated, they were the standard white color. Not a big issue I contacted them and they sent me the correct pair.
Performance:
They are extremely bright. I have yet to have anybody flash their highbeams at me when coming towards me.
Overall :
I would recommend these if you are wanting to upgrade your stock for fog lights. They are a substantial improvement over what came with the truck. If you were like me and have issues seen at night this is a worthwhile upgrade for the money.
Ford Ranger SignatureLux bi led fog lights review and pictures IMG_4493
Ford Ranger SignatureLux bi led fog lights review and pictures IMG_4486
Ford Ranger SignatureLux bi led fog lights review and pictures IMG_4487
Ford Ranger SignatureLux bi led fog lights review and pictures IMG_4488
Ford Ranger SignatureLux bi led fog lights review and pictures IMG_4491
Ford Ranger SignatureLux bi led fog lights review and pictures IMG_4489
BigOleOgre
Nate
STL MO
Field Service Engineer
Nice, soooo whatcha doin with that open box white set? Im sure signaturelux would love to have to not ship back and forth from down under. Asking for a friend
MandRonline
Gold Sponsor
Jesse
Burbank, CA
Ford ranger raptor
operation overseer
Hey guys I'm Colby, brand ambassador for M&R automotive. We have an awesome 15% off labor day sale going on from now until Monday night! You can use coupon code LABORDAY15 to get 15% of your purchase at checkout. Don't wait until it's too late!
2024+ Ford Ranger Raptor Light Bar Kits
reptarwagon
Retired Underwear Model
Be warned, these will melt the fog shrouds.
smokinjoe64
SoCal
I have not had any issues like this so far. I’ve been running mine for over a month now.
Concur 100%...installed Mar`25.
Run 'always on' w/DRLs; zero issues.
Roverhound
Walter
Fort Defiance, VA
Mechanic
They will melt the fog shrouds, not from the light itself but from magnifying sunlight.
The way I parked at my old house, the light would come in from the right and mar the left side of the shroud. Where I live now that shouldn't be a problem.
reptarwagon
Share evidence for the Signature Lux claim.
I have since replaced them with Baja Designs wide cornering, which runs cooler than the Signature Lux. I'm not the only one who has experienced heat distortion or melting on the shrouds.
You have to remember, they do no actual R&D in-house. It's all stuff found on Ali Baba they bought and then presented as their own. Hell, the early bi-led fogs they sold came from Aililaisi who reuses the same GTW-G38 box in a lot of their product photos.
We are talking about the same company that did preorders for the lava DRLs and didnt even bother to send a set to their 'influancer' flaperdoobin for a fitment check.
But you do you.
Ford Ranger SignatureLux bi led fog lights review and pictures IMG_7111
Ford Ranger SignatureLux bi led fog lights review and pictures IMG_7110
smokinjoe64
SoCal
My Comments:
" They will melt the fog shrouds, not from the light itself but from magnifying sunlight.
The way I parked at my old house, the light would come in from the right and mar the left side of the shroud... "
Appreciate sharing your stated 'unique' experience above; certainly more helpful to the Community for better context and understanding..
DD knowingly sells and markets a Hitch Mount LED for RR. Compatibility is 'sub-optimal' at best, either do not work or require hella workaround for still "maybe". So-much for DD R&D...personal experience with direct convos with DD ending in a refund.
As for China and "rebranded" products, if thas a concern "US only" good luck, likely gonna be hard pressed in todays global supply chain & economy...and yes, Ford uses many parts made in China particularly for vehicles assembled in North America. 🤔
Typical issues(s) with early Adapters and clearly stated in flaperdoobin's YT vids....no secret or surprise to potential buyers.
So, if you want product(s)certainty...buy a F-O-R-D with +1,000,000 recalls just in 2025
:wink: 😵
But you do you.
Roger that...likewise 🤘
reptarwagon
Le Sigh ...
My Comments:
Appreciate sharing your stated 'unique' experience; certainly more helpful to the Community for better context and understanding..
The way I parked at my old house, the light would come in from the right and mar the left side of the shroud...."
Even if it were the sun, the heat damage is a direct result of the Signature Lux fog lights; minimal R&D would have revealed that a projector lens might not have been the best choice. It probably would have been smarter to use a properly designed TIR lens or even a conventional reflector arrangement.
They don't market it as compatible with the RR.
You even asked DD if it was compatible, bought it anyway, then whined that it didnt work.
My favorite part about the DD HitchMount 'issue' of yours is that you didn't even acknowledge that they told you it was part of the RR's trailer module (advanced tow system above).
No clear reasons provided by DD for why seemingly kit works for some RRs while many others unsuccessful.
That shouldn't surprise me, given your past forum posts.
No, it was a "no R&D" concern.
No, fitment problems are not a problem exclusive to early adopters. That, again, is a problem that would have been fixed if proper product development had been done. I got my set of DRLs either the day before Flaperdoobin or the same day. (I ended up trashing them and found an alternative solution)
Had Signature Lux sent out his set and either paid him to do an install video, or just given him a set to do the install video with (this is common with product reviewers through T&E), the fitment problem would have been known before consumer kits were shipped.
So, if you want product(s)certainty...buy a F-O-R-D with +1,000,000 recalls just in 2025 ;) 😵
Nearly every new car has some recalls. That is one of the pitfalls of outsourcing component production to minimize costs, along with the increased complexity of cars. Blame the government for the mandated safety features and the consumer for expecting everything to be a 'smart' device.
But you do you.
Maybe not ignoring more than one report of an issue with a low-volume product to support your choice-supportive bias would be wise.
But yeah, you do you Boo Boo.
smokinjoe64
SoCal
Le Sigh ...
Ford Ranger SignatureLux bi led fog lights review and pictures {filename}
WAAAAYYY to much time on your hands bubba
...another Poster with 'gotta be right claims no matter what'
Nuff said...enjoy the fogs hoss
reptarwagon
Still sad that this is the most mature response you can conjure up.
It didn't take long to find examples of you being dumb.
