SKID PLATES?
dc73pdsgt
Mark
Tucson
2025 Ford Ranger XLT
which type of skid plate is better to use? one made of steel and powedercoated or one made of aluminum? I was thinking steel but then someone brought up the potential for rusting if scuffed up or the powder coat comes off.... aluminum won't rust but is not as sturdy... my Ranger doesn't have a skid plat currently and Im looking at the ones from RCI....
Ron Quixote
America
Several
Good aluminum skid plates are probably the right answer for a Ranger XLT. Steel skids are heavy and probably overkill for most people.
However, if you’re wheeling so hard that you are regularly gouging your skids, get steel. You can just rattle can any scrapes. And if you get rust, take it off, grind off the rust, rattle can, and party on.
The downside of steel isn’t the rust. It’s the weight.
dc73pdsgt
dc73pdsgt
Mark
Tucson
thanks for the info....
daytoncarter
Dayton
Another suggestion would be seeing if you can source FX4 takeoffs, they're pretty lightweight stamped steel and good for 95% of users. There was an aftermarket vendor selling thick aluminum skids but they weighed the same as the OE stamped steel. New aftermarket probably costs a lot more, though.
Onceaneagle
Walter
2025 Ranger Lariat
US Army Retired
Aluminum can corrode. However, it reacts with air to form an aluminum oxide coating that protects it.
ADVNTURR
Cleveland, OH
It really depends on your use case. If you are planning on taking your Ranger into very rocky terrain and doing proper crawling then without a doubt, the durability and scratch resistance of the harder steel material is likely the better option. As already mentioned, you can always clean the rust off and paint it again if it's a big issue for you, but most of the time the steel is so thick that a little rust doesn't matter.
If you're more likely to be on dirt/gravel/sand/forest trails or want piece of mind for day-to-day use then the much lighter weight aluminum skids are probably more than sufficient.
I chose to go the aluminum route because I'm towing with my truck and trying to keep weight down. I'm also hoping to do some basic trails to get to cool camping spots and such and I don't know where that might lead. I haven't hit anything with them yet, and may never, but I'm also not worried if I do.
Ford Ranger SKID PLATES? PXL_20250830_184539093
daytoncarter
Dayton
Those Rival skids seem tougher for the same weight compared to the OE FX4 skids, but what did that set cost you?
ADVNTURR
Cleveland, OH
I caught a sale or two and I bought them piece-by-piece over a year so I'm not entirely sure what I paid for the entire set (don't really want to know :p).
Coming from the Jeep world with 3/16" steel plates being the norm, it was honestly kind of nice lifting the 1/4" aluminum plates up into place to bolt them on. For the most part everything went on pretty well. I did have to loosen things a couple of times as I added plates to shift things every so slightly and I did have a slight clearance issue between the front radiator skid and the main engine skid that took a die grinder to resolve, but all-in-all I'm very happy with them.
embedded rock
Earth
One truck, two motorcycles
@ADVNTURR Can you help me with what is going on here, please? This bend suggests the plate is going over something and resulting in reduced ground clearance. What is directly above this skid plate that is being protected?
Ford Ranger SKID PLATES? 1768597804225-32
ADVNTURR
Cleveland, OH
It's a bit of an optical illusion of how much of a drop it is, but it serves 2 purposes:
Ford Ranger SKID PLATES? skids
The crossmember noted in red is recessed in the middle where the bolts are. They could have spaced it out with washers but chose to bend the skid tabs into it.
The other function is that it brings the plate level with the 2 crossmembers noted in green further back.
All of the plates are roughly level with each other. Is it a perfectly smooth belly great for sliding across stuff...no...but it's reasonably close. All of the plates are also stacked so that assuming you're moving forward you always ride down onto the next plate so you don't hook it.
embedded rock
Earth
Thanks @ADVNTURR. That being the situation, does the t-case plate and supplied cross-member require the transmission skid plate to keep the slid surface continuous between the two plates?
Edit: Just noticed the vids in the Rival website are yours. I'll have a closer look and maybe have some more questions answered.
pasali
Paul
Livermore CA
Carpenter
I have all the Rival skid plates as seen in the above photos and have been thrashing them rock crawling in my RR on several trails including Top of the World, Hells Revenge in Moab, several trails in Sand Hollow and the Toqeurville falls trail outside of St.George Utah. They are tougher than one might think. To me they are somewhat sacrificial in that if they bend to the point that they need to be replaced, they have done their job. I don’t know how they compare to steel in terms of weight savings, but they have held up really well.
