So turn by turn directions just appeared
NevadaBob
Nevada
2024 Ranger Lariat
I have a 24 Lariat. When using Android Auto I've always had a tiny arrow at the top of the dash display telling me where to turn. This morning, a much bigger display showed up for about 5 minutes, then disappeared. A few lights later it's was there again.
Picture shows the big directions on the bottom. I've never seen this before on this truck. I like it, but it doesn't seem to stick around for very long. Had anyone else seen this?
Ford Ranger So turn by turn directions just appeared 1000012064
ericsmr
FordGuy
West Coast
2025 Ford Ranger XLT FX4
Hola Amigo saludos desde Argentina. En mi modelo aparece similar, y solo cuando estas proximo a una curva, luego desaparece para evitar que sea invasivo. espero ayudar
“Hi friend, greetings from Argentina. On my model this appears similarly and only when you are about to turn/close to turning, then it disappears to avoid being invasive. Hope this helps” :)
NevadaBob
Nevada
2024 Ranger Lariat
Hola, e gracias! That's exactly what appears to be happening. Thanks!
chasc
Illinois
2024 Ranger
I don’t remember if it was default or had to be enabled with a menu but my Lariat shows that large center view when very close to the turn and upcoming turns further out go up between the 4 gauges at the top.
Wayfaring Ranger
STL
This feature has been working in my truck for the last 2 years. It appears when you're about .3 miles away from a turn and then it goes away when you make the turn.
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
I have found this only works with certain navigation apps. For instance, you do not get the integration using Waze. But Google Maps it does show up.
