Solutions for raising driver's seat
Good luck with your mod. I brought ones for the front. I only used half of them and was very impressed with the quality of the parts.
Thanks, I bought two sets, but I am planning on trying a couple on the back of the driver seat and see how that feels, it works like I think it will, I will be putting the other set on my other RR driver seat.
Thanks again for the link and info on these.
ATestBishop
Alex
Walnut Creek, CA
2024 Ford Ranger XL
I cut and drilled 2 pairs to use on both front seats to lift the front brackets up from a small aluminum billet, it was quite the hack job to be sure but even ignoring any sloped contouring they are solid and flush front and back. I can check thickness but is was 6-7mm I believe
BigBassDaddy407
2025 Ranger XLT 4x4
Would like to raise the driver's seat 3/4"-1". Desert Does It says I will need two sets of their seat jackers to do this - $169.99. Seems pretty pricey for a handful of spacers. Any alternatives ?
You might be able to unbolt the seat and stack a bunch of relatively wide washers underneath, then bolt it back down. Might need longer bolts. I've never looked at them though.
The Lone Ranger
The Lone Ranger
Oregon
2024 Lariat
I ended up using some composite material (UHMW I believe it is called) made for pads for boat trailers and other things. Cut them to length and drilled holes. Since I have a Lariat, I didn't think I needed the slant like on new ones you can purchase, since I can adjust front up with power seat control if needed. Bought longer bolts - install was easier than I expected.
