Stick On Blind Spot Mirrors
got3fords
James
Central Va.
LeeHo
Lee
Niles, Mi.
Unless you have a base trim XL, all other trim levels come with BLIS built in. A corner mirror is OK – but not 100% necessary. Note that the BLIS indicator is on the outside edge of the mirror so if you do decide on a stickon, be careful not to block the BLIS. Perhaps this is why you are having problems finding a stick on for the GEN 6
got3fords
got3fords
James
Central Va.
Good point, although the ones I had on the 5G were specifically made to be attached where they wouldn't affect the BLIS. So I would assume they could be made for the 6G as well.
got3fords
got3fords
James
Central Va.
I bought those exact ones, don’t line up at all with the 6g mirror but work enough for me to see a little bit more
Good to know, did you put them in the bottom outside corner?
gmpetrie
gordon
california usa
2015 Ford F-150
These work well with my '25 Lariat . . . .
Ford Ranger Stick On Blind Spot Mirrors IMG_1664
On Amazon: Blind Spot Mirror
I like it because I can see what's coming up from behind before the Blind Spot Detection engages. I don't need it on the passenger side because that mirror adequately has wider field of view.
bigb
Tucson
2025 Ranger 2.7
Not trying to sound snarky but I've found that when the mirrors are properly adjusted there are no blind spots. I also usually do the "glance over the shoulder" thing just to be doubly sure.
If a vehicle does not appear in your side view mirror just as it is disappearing from your rear view mirror the mirrors are not properly adjusted.
got3fords
got3fords
James
Central Va.
Well, confirmed the custom fit ones wont' be available for the Raptor for some time. A company rep confirmed there are not enough 6G Rangers out there to justify the cost of designing a custom fit product. He then recommend the ones for the 5G even though they are not a custom fit.
got3fords
got3fords
James
Central Va.
I will take any visibility advantage I can get. And yes, my mirrors are properly aligned.
Rangerjimm
SC
2025 Ranger Lariat 2.3
The 2" round ones you can get at Advanced Auto for like 4 bucks work great in that same location on the Ranger mirrors. I did buy the custom Nextgen ones for the wifes BMW X5 since that mirror is an odd shape.
