- Joined
- Feb 27, 2025
- Threads
- 28
- Messages
- 786
- Reaction score
- 1,150
- Location
- United States
- Vehicle(s)
- 2024 Ranger Raptor
- Occupation
- Electrical Engineer
- Thread starter
- #1
So far, my research has yielded around 30-35 PSI for packed sand / dirt baja if you're doing higher speed stuff on non-bead grip or non-bead locked wheels to avoid de-beading. Will also be jumping it, so I dont' want a pinch flat during landing (already jumped it in an undisclosed off-road location at 84 mph and loved it!).
Starting to plan a trip up to Silver Lake Michigan early fall next year (late Sept. early Oct timeframe) and I will have a set of Method 703's by that point (waiting a while just in case they decide to produce the 207 Forged wheels or a +55mm offset, if not I'll buy the Bronco spec 703's in +35mm that are hub centric from FP).
What pressures do people run for higher speed uses with the method bead grips? I'm thinking 25 PSI on methods would be safe for baja in sand dunes. I tend to push the truck performance wise (habit from hot lapping a 2016 Mustang GT), just want to avoid destroying a tire.
Right now, I have the factory bead lockers but given the PITA it is to get the bead locked and the cost of the rings + labor is nearly as much as a set of 703's....hard to justify. I may keep the factory lockers and use them for trails since the beauty rings can be replaced / repainted, so they would make good trail / crawling wheels.
703's would be my street / baja wheels due to the lighter weight (less rotating mass) and bead grip. I ran two sets of tires / wheels on my mustang for different applications (kept the factory wheels for all seasons in colder weather, set of RTR flow forged with Pilot Sport 4S's for track / auto x / summer), and it worked out really well, so thinking the same thing for the truck. I have zero need for lighter wheels when doing trails / crawling since that's not high speed, in fact I'd rather have the forged factory lockers with rings that I can replace for those applications which is why I got the truck with the factory forged lockers.
But for Baja and daily driving? I think bead grips all the way; question is what tire pressure can I push them down to for Baja? 10-15 PSI seems way too low for high-speed stuff / jumps even with Bead grips.
