Tonneau cover shopping today
452Ranger
Illinois
2024 Lariat, 2017 Miata GT RF, Volvo V90
Just remember that with any tonneau that doesn't fully cover the bed rails that water will enter thru the bed caps. You need to use silicon or some other type of sealer around each bed cap to keep the water out.
Hope this helps.
Ford Ranger Tonneau  cover shopping today IMG_2992-1
wlarsen76
Wells
I'm researching the EGR Rolltrac. I guess they are sort of big on the Ranger Raptors in Australia. I'm trying to find out if they are compatible with the Yakima Overhaul HD system. I'm also a little wary about drilling, but I figure I can probably get rubber plugs to make it look nicer if I every remove the cover.
JrHDRanger
Indiana
I ordered a lowmax. I chose it because it does not have a foam core, or need for drain tube. Apparently the covers with a foam core absorb moisture after time and become really heavy.
Any tips for installing. I installed mine a few weeks ago and it isn’t tight when I close it especially in the back, I can move it up and down. There is a gap between the clip on the cover and side rail where it clips under. I have reinstalled the rails multiple times and the ribbed clamps that hold the side rail can’t go any higher. The rails are level. I thought about somehow attaching some kind of shim under the rail to take out the space and hold the clip on the cover firm to the rail, but haven’t come up with a good way to do that.
greaserman
Eric
Alliston, Ontario, Canada
2024 Ford Ranger XLT
Machinist
Wish I could help, but I can't. I had mine installed where I bought it.
JrHDRanger
Indiana
I found a solution. Cut 2 small rectangular pieces of .5mm shim and painted black, stuck them to red 3M tape and put under rail where the clip for the top latches under. Was the perfect thickness. Holds tight now and can’t see what I added at all.
greaserman
Eric
Machinist
Awesome idea!
