(Vendor Update) Stay Away from f150leds.com
ClingleBerry
2025 ranger raptor
Lots of posts they don't fit without modification. F150led is definitely in the wrong here.
I just installed mine and they definitely require modification to install and are not plug-n-play. Heck, I had to sand the center light down to make it thin enough to fit into the grill slot and didn’t stick out 1/2 an inch. Also had to “wallow” out the holes to get the wires fished through. The build quality is good on the lights but they were clumsy to install and not something I’d recommend especially at the current price point.
Freedom Beast
James
2024 Ford Ranger XLT FX4
I have one
I have them installed on my non RR. Build quality is superb. Bright as crap. Easy as crap to install also per supplied directions and the video. However, after about 6 months of use, they no longer work with the auto light function on. Neither do the side markers now. The DRLs work. The Rap lights and side markers only work when the headlights are actually turned on. Not sure if it's a fuse or a BCM module.
***Side note, I may have to pull them out and put some extra 3M tape on them. They are kinda getting a little wobbly***
ChronciallyChronic
Central Florida
2024 Ford Ranger Lariat
Huh, learn something new every day....I did not know crap was easy to install, didn't know crap was bright either.
Freedom Beast
James
I have one
Maybe
Brock
CA
23 Bronco, 24 Mustang GT
Isn’t this the company owned by Adam Dailey?
CTRaptor92
CT
I had similar issues with my installation. They just don't fit and that's clear as day. A dremel isn't going to make them fit. They also do not easily connect to the side markers - you need to partially remove the panel in the wheel well to get to the wire tap-in harness. I only found this out after scouring the forums for side marker light exchanges.
NASSTY
ME
I tapered down the rear of the housings to make them fit.
Sauce
Northeast
2025 Ranger XLT FX4
CTRaptor92
CT
It wasn't an issue of tapering the back of the lights like they say on the website - my issue was getting the top and bottom dimensions to fit inside the grill housing. It was just too tight of a squeeze.
Jake
Orlando FL
2024 Azure Gray Raptor
They have posted a few times in this forum that they are coming out with direct fit RR lights. Just hold off until those are released
