Wireless charging pad - can it be retrofit installed?
buzzleo
LA.....lower Al
Not yet an owner
Anyone know if u can buy the wireless charging pad for a truck that doesn't have one. There is a blank spot on the console for it. Maybe the wires are under there also!
Reddog99
So. Cal.
2024 XLT Ranger FX4 2.7
If you have a Apple phone, just buy a Magsafe charger. It plugs into the USB-C port.
buzzleo
LA.....lower Al
Not yet an owner
Have android. Maybe they have one also! Didn't think about that.....
FirstFord1
William
Suttons Bay
Ranger
If I were to pick one thing about my Ranger, that was a waste of space, it would be the factory wireless charger. All mine does is make the phone hot and maybe add a small battery percentage increase. I even purchased a new MagSafe case and have tried charging with the case off. Then I read that you should be careful what is placed on top of the charger besides a phone, and that it could be a fire hazard. Coming from a full size truck, it is a disappointment to have the reduced storage options wasted. I should probably pull the fuse for it, so I don’t have to worry about it.
buzzleo
LA.....lower Al
Not yet an owner
Thx for the info. I've seen where people have said it doesn't work well.
purdyd
california
Yes the wireless charging pad is a disappointment.
they should have cut a notch in the pad for the camera bump on phones
and qi2 with magnetic alignment and holding it in place
there was a thread on here about putting the phone in upside down helping.
I tried it, maybe that it better
i personally would not bother adding the wireless charging pad And get a usb wireless charging pad instead. Those at least work.
I have one on my Lariat I just use it for extra storage space. :clap:
waffleso_0
Oakland California
24 Ranger XLT 2.7L V6
Does anyone know the fuse needed to turn the wireless charger off? I noticed the same thing as Firstford1..phone gets hot and does not charge that much. I have a pixel 9 pro
