Deleted member 8167
So I used my ford points to pay for most of these rails. Install was relatively simple. You pull back the bed cap as part of the install rather than remove it all together.
It does look like it will interfere with a rack like the Kuat Ibex, but I’m not totally sure. The three brackets probably get in the way of anything that clamps to the bed rails.
It doesn’t interfere with Decked though. So that’s nice. The instructions were impossible to find pre purchase so here’s a link to them now.
https://www.motorcraftservice.com/InstructionSheets/Get
https://www.fordservicecontent.com/...s/2023_CMY_Ranger_Cargo_Management_System.pdf
Ford Ranger The Cargo Management Rail System installed IMG_4045
Ford Ranger The Cargo Management Rail System installed IMG_4046
Ford Ranger The Cargo Management Rail System installed IMG_4047
Deleted member 8167
Gotta say that motorcraft instruction link is really nice if you’re looking at any ford accessory.
CherryCoke
Las Vegas
Drinking CherryCoke
@StillwaterRaptor, I've been thinking about getting these but seen they were a little on the pricey side. What did you pay for them ?
Deleted member 8167
It was like 400 but at 200 with my points.
The OEM parts providers have them at 300ish
so 200 wasn’t bad in my mind.
jrRaptor
Maize, KS
Plus on Ford Accessory site use coupon code to get 20% off. It changes every month code is SHOP524 for May. Will likely be SHOP624 for June, SHOP724 for July, etc...
Fattirz in NC
Charlotte, NC
Designer/Draftsman
Odd to me they are white? Usually accessories like these are in black?
Rapture2423
Midwest
Wish you could use these with the Bak x4s tonneau cover. Ended up with a bed extender instead.
Crapblaster
I have a Bak x4s and have the rails on order. I think I can make it work after looking at different install pictures.
tpack424
2024 Ford Ranger XLT FX4
Let us know how it turns out! I’d be interested in doing the same if it’s possible.
24'Ranger
Kevin
MN
2009 Vibe AWD, 2019 Outback, 2024 Ranger?
I too am interested in them but don't want to pay that much for a few pieces of metal. I'm looking at and trying to figure out how to mount L-Tract or Strut Channel to the bed as a DIY approach.
pablo94sc
Focus
There are 4 captured nuts tucked into the sides of the bed at a slight angle underneath the bed rail. They are basically in the front half of the bed only, but shouldn't be an issue running a channel strut the length of the bed inset.
There are quite a few captured nuts positioned around the bed and along the bottom of the rails. No idea what they are all for, but definitely handy to have.
Tomikaze
Tom
Portland, Maine
24’ Cactus Gray Ranger Raptor
Automotive Software
Wish they had one piece that ran across the front of the bed. My Tacoma had one and that's how I mounted my mountain bike fork.
J.Dub
Joshua
Livermore
Millwrights
Could you use this to mount a bed rack too?
Deleted member 8167
Not sure. They kinda look like t-slot systems but they seem a bunch wider than a-slot hardware I’ve used before. I think it’s a No.
