2024 Ranger automatic gear display.
fordtrks4ever
Perkiomenville, Pa
I have a Lariat and have tried to configure my display like yours. Is this available only on the Raptor or is it found in the settings somewhere? I’d like to have the small icons across the top like yours, or something similar
It in the dash menu under gauges.
My Lariat looks like that with the gauges I want at the top.
sammydon
Jackson Georgia
Sorry, I have an XLT, not a Lariat. Brain fart. I found them when I switched to off-road gauge view. Not across the top but still visible. Thanks
fordtrks4ever
Perkiomenville, Pa
Yes XLT has the gauges on the sides.
JR RANGER
JR RANGER
JR
Auburn CA
2024 Ranger XLT FX4 4x4
I think there is another option… something like “manual mode gear shift indicator”…you can find it from the steering wheel options…and if you turn that on, it will display your gear permanently so you don’t have to press anything when you turn your truck on.
Mine doesn't have any options on the stearing wh
Could you indicate what you are turning on in this screen, or do you have to be in S mode to do this? I see you have turn by turn checked on this screen. Is that what your talking about?
I talking about being able to turn on the display that shows you what gear you transmission is in while your driving
fordtrks4ever
Perkiomenville, Pa
If there is a plus minus on your Transmission selector when in gear hit the plus
That works on my lariat. Should on the XLT also I believe.
JR RANGER
JR RANGER
JR
Auburn CA
Got it figured it.
Thanks for the response
JR
sulnw
suthep
Thailand
Ranger Stormtrak
construct
FYI
Just found out if you want to monitor in real time what gear your transmission is in. Start your engine with your foot on the brake and press and hold the + button on the console shifter
. It will be displayed on the main screen to the right of the gear selector display.
Ford Ranger 2024 Ranger automatic gear display. c18df181-e2b4-4feb-ad52-62f4694a00fc-1_all_46688
BriSco
'24 Ranger XLT, 2.7L V6
That feature has been there since 2019 that I know of. Then you can hit the minus button repeatedly to set the highest gear you want to use as well. Works a treat for a city truck.
