steveconnery
British Columbia, BC
Ranger XLT FX4
Did you use the 5100 in the rear to lift at all? Was considering getting a lift block and adding the 5100 from the 5G in mine.
I did the same as you with the bronco front suspension, it’s great but I’m considering lifting it a little more to match the potential rear. Are the 5100 from the 5G the exact same length?
DrewR
Drew
Virginia
2025 Ford Ranger XLT
Sorry, I know this is an old thread but had a question about your wheel and tire clearance to the knuckle. I just picked up the same wheels for my stock 25 XLT FX4 and am going to run 265/70R17 KO3s. Hoping I won’t have any clearance issues with the suspension. I’d like to avoid doing a level for now if possible. Thanks!
Clay6GRanger
Clay6GRanger
Clayton
Arizona
2024 Ford Ranger XLT FX4
Yeah those are only 1cm wider than the stock tires, should be fine on the stock wheels even !
