Gravy Jones
GTI
Well finally had my new wheels put on. These are the Method 703's ordered directly from Ford that come as a set of 5. Went with these as I wanted something lighter than the factory beadlocks as well as hub-centric. I know these are pretty common and many folks don't care for black but they work for me.
Specs: 17x8.5, +35mm, 93.25 center bore, 28.5lbs.
https://www.ford.com/product/20212024-bronco-method-17-x-85-wheel-kit-matte-black-p4000006499
Is it odd that the link says these are not compatible with the Ranger?
boraxman
boraxman
Santa Clarita, Ca. USA
I noticed that too, maybe the offset spec? I can assure they fit and stick out about 3/4" farther than the stock +55, zero issues, of course I have not tried a full air jump yet (probably never will).
Gravy Jones
GTI
Biggest problem is they are on national back order. At least the black ones. Tire Rack doesn’t have them. My dealer can’t get them. They found one and only one available at another dealer in the southeast. Method says 2-3 months minimum.
RaptrJr
FL
They have no issues when jumping.
Jay_Ox_RR
Jay
Pittsburgh, PA
I ordered a set of bronze from Ford directly and can't wait for them to arrive.
Do you need to use the lug nuts: M-1012K-BR?
boraxman
boraxman
Awesome. Thank you.
Did you use one of the method wheels for the spare? The kit comes with 5 wheels, so I was hoping there are no issues fitting one under the bed
I did not myself but others have, its doable.
